1 are they the standard fog lights?, are they getting 12v? what is the condition of the globes? the switch on the dash should control them when driving and or parking lights are activated, so someone has stuffed around with the wiring, check it over...
if everything is fine and the bulbs are just dull, pull one bulb out and take it to a automotive shop to match up with another newie, there is no application listing for driving light style bulbs so you have to take an example in with you. Narva make a replacement bulb called 'plus 30 & plus 50'. they increase intensity and beam distance 30 & 50% repectively at the same power rating.
2 small leaks are pretty common from the rack, if its minor just visit a car store and get some universal rack boots, dont forget to take your old one in to get a similar size. and yeah clean the shit off the rod before you install the new boot.
if its a serious leak, look at having the rack checked out and or rebuilt. no cheap...
3. the oxygen sensor allows the computer to improve fuel economy when cruising and also helps the efficiency of the cat converter. its not totally neccessary you can try unplugging it to see if it helps your situation. you can also try resetting the ecu by leaving it unplugged for a few hours.
