Results 1 to 15 of 15
Thread: 1G bottom end
    Default 1G bottom end
    Hey guys a couple of questions about the 1G motor
    Do the 1G gte/gze bottom end come forged from the factory? And if they do, are they able to be switched with the 1gfe(is200) bottom end?
    Reason I ask is that I plan to go ahead with a small turbo conversion on my is200.
    Cheers in advance
    Default Re: 1G bottom end
    Mate, there arent many cars from the factory with forged cranks and conrods. Some have forged pistons, but its usually not much of a job.
    Best option for a tubro 1G is to use at least pistons from a 1G-GTE, if not the whole bottom end (just because its easier).
    I believe crank bearing part number for 1G-G/T/F are all the same - so should all work.
    However, head is really different on FE and valves might interfer with pistons - probably not as GTE is 8.5:1 compression. Also, GZE is 8.0:1 so dont bother trying to find them.
    Oh, and this has already been done, the bloke ditched it for a JZ after spending a lot of money with the same idea as you.
    Ah thanks for the info. Im not chasing too much power just a little bit more and more torque. Driven an IS with a 1J and wasn't entirely happy with the way the motor sat and it upset the balance of the car a bit too much for my liking.
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    If you are just after a bit more torque, why not super charge what you have???
    I can confirm that the rev 3 1G-GTE actually has the same crank as the IS200, the rods and pistons are very different. Due to the lower compression the 1G-GTE is a not a great producer of low end grunt, hence why, if you are just after increased driveability instead of huge power a 'charger makes sense. there are a few IS200 kits out there
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    Forum Member Domestic Engineer Nark's Avatar
    ACT-ish
    APS do a kit. $8k drive in drive out I think.
    128rwkW.
    Max
    NB8B MX-5 | Fulcrum-tuned Tein SS coilovers | Weldwell Engineering 4 point Rollbar | DBA 4000 slotted rotors | Goodridge braided lines
    MY11 Skoda Octavia RS wagon | 2x ISOFIX seats | Iggle Piggle's blanket | Some breast milk stains
    your mums an Carport Converter pato's Avatar
    for 8k id be wanting a bit more than 128rwkw
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    ACT-ish
    114fwkW to 128rwkW not good enough for you?
    Max
    "confused" how do u make it rear wheel drive by adding a supercharger ?
    ACT-ish
    fwkW = Fly wheel kilowatts
    rwkW = Rear wheel kilowatts
    Rough measure is that there's 30%-40% loss from the flywheel to the rear wheels.
    So taking the 30% number 128rwkW = ~183fwkW
    Oh and it's a turbocharger kit.
    Max
    New Zealand
    30 to 40% is an EXTREMELY optimistic figure. For example my car was approx 20% (FWD car) with 140k on the clock.
    Callum
    ACT-ish
    FWD = less drivetrain loss.
    It's all guesstimation anyway. That's why I only quoted the rwkW figure to begin with. The calculation was done as part of the explanation.
    Max
    i allways thought of fwkw = front wheel kilowatts, the same as rwkw = rear wheel kilowatts.
    just kw = flywheel kws.
    even still . for 8k id be wanting a bit more than 128rwkw. my 1g made 171rwkw and i dont think ive spent 8k on the whole car, including purchase
    ACT-ish
    Quote Originally Posted by pato
    I'm not sure what that proves in relation to getting more power out of a 1G-FE IS200?
    Max
    nothing really.. except what i said.. id be wanting more power if i was going to spend 8k on something
    sell it
  1. 1UZ bottom end bits
    By mrshin in forum Tech and Conversions
    Last Post: 25-07-2006, 07:58 PM
  2. 1JZ bottom end torque specs
    By 1JZ-Rolla in forum Tech and Conversions
    Last Post: 11-06-2006, 09:51 AM
  3. Repairing 20V bottom end bearing
    By Dimmy in forum Tech and Conversions
    Last Post: 29-03-2006, 10:24 PM
