Results 1 to 15 of 19
Thread: TA22 Leaks in Rain
    Default TA22 Leaks in Rain
    Howdy,
    Noticed in the rain on the weekend hat after awhile water starts to drip on my foot and also drips in the passenger foot area as well.I think it somehow gets in from the vents before the front windscreen.Any ideas on how to fix it?
    Thanks
    Default Re: TA22 Leaks in Rain
    I'd be looking real close at your window seals, especially at the bottom 'cos water can get in there and track down inside behind the dash and onto your carpet.
    seeyuzz
    river
    Western Aus
    cant remember if the TA22's have a frame around the top of the window...?
    i dont think they do...?
    if they dont, thats probably where its leaking from, my supras only 17 years old (not young, but young compared to a 22) and it leaks like a sieve from there!
    also, look for water tracks above the leak, do it after you wash the car, and look above the leak all round for wet patches/runs, then follow it upwards and you'll find it.
    water with dye in it helps, easier to see, but it can stain the interior.
    Elmo.
    lol... saw the thread title and had to laugh... first thing that came into my head was "DUH!" every celica owner i've spoken to complains about the same thing...
    dana just rain proofed her windows with a strategically placed tube of silicone sealant... strategically placed everywhere around the edge of the glass that is.
    i doubt it's the vents in front of the screen, unless there's rust in the well beneath the vent even then, i believe those wells trail out to the side of the car behind the quarter panel.
    '77 RA28LT #2 ← 2.2L 18RG...
    yeah... its just old window seals.
    Both of my RA28's have done it.
    Administrator Domestic Engineer mynameisrodney's Avatar
    the vents in my car were rusted through. and the hole was directly above drivers feet, so i wouldn't rule it out just yet.
    not to mention rust!
    I am the sun
    If you are concerned about the possibility of rust causing the leak. The main culprit, is the boxed section in the air chamber above the heater. But if your feet are getting wet, almost a sure bet the windscreen seal is leaking. Even new seals will leak. Just have to make sure you add heaps of windscreen sealant between the glass, and the seal.
    Aaaand do not put acetic cure silicone anywhere near your Classic Celica, that crap just promotes rust, by eating through the paint, and then into the metal.
    cheers Chuck.
    MS51Crown Coupe,
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    get it check out coz you dont want it to leak onto your fuse box, and touch wood mine hasnt leaked,
    should check it after all this rain we have had
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Thanks for all the info.I think that the seals are pretty old so will check them first then look at maybe the rust issue.Hopefully it isjust the window seals.
    Cheers Pete
    good luck finding new genuine seals, heard the price isnt pretty, and the not so genuine stuff isnt the best,
    just thought you should know, but hopfully some one with some experience can help you out with that
    wheres the members ride on you beast
    Banned Backyard Mechanic Scoobzd's Avatar
    Apr 2007
    bwahahahah..... ive sealed up all of my windows and still havent got it right my back seat gets a little bit wet and my boot fills up with water in the rain....
    Silastic Windscreen sealant works well - i've used it a few times with success.
    if you used it with success... why would you need to use it again? and again?
    lol... sounds a bit like "i quit smoking successfully... 5 times!"
    ->i know... i know... more then one window/car<-
    GT4 Freak, and Conversion King Squid's Avatar
    I have had luck getting my window seals to re-seal properly just by treating the existing ones with armour all. A liberal application weekly for a few months sorted it, and stopped an annoying squeek/air leak while I was at it. So if it is your window seals, give that a try?
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 11:02 AM
  2. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
