Results 16 to 30 of 35
Thread: 1g problem
    Default Re: 1g problem
    wipe the code (disconnect battery) then start it then recheck, u dont know how long that code has been in there.
    your mums an Carport Converter pato's Avatar
    fair enough ..... ill give that a try ..
    my afc neo reads my airflow from 0.3% to around 69.8% is this normal ???
    ive never really worried about it but after this code iam not sure any more
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    check the oil level, 1gs chew oil, and when low they feel slower....as was the case for a mates GZ20 soarer,
    how much you after for the motor if you sell?
    nah .. its got plenty of oil.. i check it all the time cause it does chew a little
    but it fells exactly the same at all times except when its on full booost.. so i dont kno
    i disconnected the battery, pluged it back in .. started it ... then retested and got the same code.. 31 ..
    ive turned the boost down to stock and ill take it for a drive to see what its like when it stops raining..
    no idea.. i was going to sell the motor in the jza70 halfcut, so essentially it will be a ga70 halfcut
    how much do you recon would be a fair price ?, ive seen a few on cvap
    haha yeah the 1g factory turbs burn the oil like no tomoz,
    id pay for your 1g 1/4 of what you are probably asking, lol
    for a complete front with complete loom, gbox, you may get $1000, for a short block/head you'd get $100,
    cheers anyway, blake
    on cvap they wanted $2800 for a gen 3 halfcut with the w58, but i kinda figured they were overpriced, esp. seeings they were trying to sell a ga70 fmic for $280 lol
    i was hoping for around $1500-2000, but ill just sell it for what its worth i guess, ill worry bout that when i actually get it out of the car.
    took the car for a drive on stock boost and the same thing happened
    same error code too, 31
    but my neo was showing me 58% air flow, 10% less than on upped boost, so i guess my afm is working ok.
    Quote Originally Posted by TheToyman75
    Pato,
    Its only a guess but it sounds to me like knock retard.
    is there anyway of turning this off ? , some sort of terminal jumping configuration ?
    if i left the thing jumped at t1 and e1 wouldnt this cancel out all auto timing.. or would this be a really bad idea ??
    User Conversion King
    NWA
    intersting suggestions so far.... :S
    i once had a poor power supply to one of the ecu pins (+b i think). it ran in limp mode and felt slow as at 16psi boost. it would boost but go nowhere at all.
    all fixed now though.
    code 31 is air flow meter. the ecu probably senses the problem and runs in limp mode to save the engine
    hello
    yea.. i definatly think the engine is running in limp mode..
    shoudl if feel all good.. but wont work on full throttle with full boost..
    how do i get it out of this mode tho .. so confusing :s
    NWA
    take the battery terminal off for a minute to clear the codes.
    it will probly go hard for the first second until the ecu picks up the problem.
    try borrowing a AFM
    hello
    i disconnected the battery .. pluged it back in and bam.. problem was stilll there .
    i wish .. dont know anyone anywhere which would have one spare
    ill just get the daym 1j .. or keep lookin for a afm
    NWA
    a 7M AFM is identical but be warned your engine will ping. the spring tension is much higher.
    have a look in the forsale sections there is a million 1gs wrecking now
    hello
    thanks mate.. ill have a look
    I have several knock sensors that I could supply for basically just the postage if your interested...
    Facebook | LinkedIn
    Western Aus
    correction, 7MGE.
    7MGE is flap type, GTE is karmann vortex, therefore, incompatible with yours.
    Elmo.
    well i found a afm, swaped it over and tried again .. and it was exactly the same.
    so there is nothing wrong with that.
    iam thinking there is some small pain in the ass electronical problem causing this and i really cbf finding
    hopefully ill be gettting my 1j halfcut on sat and then i can just put that in and be happy
  1. Common Problem AE71/KE70 (Now with pics) Headlight/indicator Switch
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 18-07-2006, 06:13 PM
  2. Ra23 electrical problem.
    By rob1 in forum Tech and Conversions
    Last Post: 17-06-2006, 05:39 PM
  3. TPS Problem
    Last Post: 28-04-2006, 03:10 PM
