You need to weld/braze a short length of pipe to the side of the sump, the same diameter as the turbo oil drain and directly below it, then join the two with a length of heat-resistant hose. It's important to make the path as direct and as close to vertical as possible - the oil coming out of a turbo is frothy and doesn't flow too good.
