thanks anyway
Hey does anyone know anything bout K40's?
thanks anyway
i know they are a 4 speed gearbox that come from ke20s and ke30s. i have one in my garage. what kind of info are you after my friend. did yo try google or searching the old toymods site?
well i have quite an odd question
I have a ke70 with the k40 box (well i gues it is i'm not expert) and the person before me has chewed the head on th bolt on the side.
I discovered this after i drained it so now i can't drive my car till i fill it with oil again.
Wot i need to know is, is it possible to put oil throgh the opening t the top where the swith for teh reverse lights bolts in? i have put a peice of wire in and it doesn't appear to go in very deep i m desperate to get oil in it as i need it on the road tommrow morning for work.
i believe you could put it down the shift hole. move the cover were the shifter goes in and see if you can see oil. if so pour away just dont over fill it.
k40 scroll down
Oil Fill Quantities
K40 - 1.7L
yup, unbolt the shifter, pull it out, and fill from the top....
thats how i usually do it anyway![]()
If you want to eventually undo the filler plug, weld a sturdy bit of rod to it. Then slide a long bit of water pipe over that and undo it. The plug is munted anyway. Fit new plug.
forgot to mention this will be really really really slow to do... the reverse switch is activated by the shift rods, but i can't remember if the rod completely pulls away rom the switch or not... i would suggest it doesn't as it goes forward into the front section of the casing...Originally Posted by Vella
go the shifter hole.. pan in the arse but....
Edited post.
whch are weaker and what is your proof
have you compared both boxes side by side to see the size of bearings and gear teeth?
(i mean between KE10, KE20, KE30, KE70 4 and 5 speeds?)
Edited post.
well.. the gears are the same size, most of the bearings are the same size.. there is a diferent arrangement for 5th gear, but that should not affect it.
most K series boxes break 2nd gear. this is no different between 4 spd and 5spd.
there was one guy who broke the extension housing off, but iirc, that was due to a broken uni joint, thrashing it around.
as far as i can see, from having lined up the boxes, and from having used them both, there is no difference between them.
both K40 and K50 (from KE10 thru to KE70) will all break 2nd gear if treated badly.
i know ppl have said from time to time that their 5 speeds broke, but often the 5spd was put in after engine upgrade, or they didn't run 4 speeds or whatever... anyway.. thats my 2ci changed to 5speed after a put the fuel injection on my 4K and it didn't break
unlike the 5 or 6 (or was it 7?) K40's before it....
Edited post.
Thanks for all the info guys, i ended up up till 12 last night, yes i removed the shifter in the end.
And to confirm wot old corollas said,
Yes it takes bloody ages to fill through the reverse light ohle, hence the reason why i gave up and pulled the shifter.
Yes i would like to upgrade to a K50, but unfortunately time and money is an issue
You have all proved very knowledgable and helped heaps cheers guys reputation points for all.
1 more question, wot happens if by chance there is slighty to much oil/oil stabiliser in there? LoL i must sound like the biggest back yard amateur.
too much oil is not so bad.. worst is it would leak out front and rear seals perhaps..
oil stabiliser?
