To start with, your gramma and punctuation is a little lacking, the facke that your whole post was one sentence and had no capitalisation whatsoever did make it hard. Secondly, how did you cram 18R pistons into a 2TG?? Yes there most certainly is a difference between the 18R and 18RG pistons, and there are 3 types of 18RG pistons to make things more confusing. Posting a pic of your piston will be most beneficial. If they are indeed 9.7 pistons, then they are 18RG domed pistons. Any of the RG pistons are hard to find, and usually sell for $600 a set or more, unless you can get a good second hand item. You will also need to measure and check for an overbore size.
Another thing to consider is that if you have 18R pistons in a 2TG, then the compression ratio will be much greater than what the piston will be stamped with. A factor to consider when tuning.
