Page 6 of 6 FirstFirst ... 456
Results 76 to 79 of 79
Thread: MA70 caliper, to hilux diff bracket
  1. #76
    Default Re: MA70 caliper, to hilux diff bracket
    Quote Originally Posted by 1JZ~lux View Post
    Original threads with more detail on what to do for the MA70 gear to work can be found here:
    https://r.tapatalk.com/shareLink?url...0&share_type=t
    and
    http://www.toymods.net/forums/showthread.php?t=2766
    Sent from my SM-G950F using Tapatalk
    Yes, I used those - just bear in mind the orientation is wrong if using the nissan bracket / caliper.
  2. #77
    Thanks for the feedback bananaman, and also for the link 1jz-rolla. I've been looking for that thread for ages and can never find it!
    Any other tips or issues I'll likely run into doing this to a 4x4 diff? Most of the info seems to be around 4x2 diffs. Not sure if there are any other differences around from hub bore and stud count/pcd.
    Never late in an x8
  3. #78
    The 4x4 diff's are practically the same, just the leaves mount on top instead of underneath. Probably just watch the cable and hose lengths in case you need to use longer.
  4. #79
    Cool, thanks.
    I've actually been working on another conversion, with an integrated handbrake. Waiting on parts til i can design the caliper bracket but hopefully it goes ok. If not I'll go the R33/MA70 route as i should already have most of the parts for it
    Never late in an x8
  1. How to: Supra MA70 rear discs to Hilux
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 13-01-2019, 12:12 PM
  2. ma70 disc on hilux diff in ra28
    By ra_28 in forum Tech and Conversions
    Last Post: 04-01-2007, 04:52 PM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
