go 2jz if ya do it
sorry not much help am i
dont know of anyone on here doing anything like this.
Gerald
Hey guys not really the forum for this question however has anyone seen or know any web pages on info of this engine swap.
My e34 runs a getrag 5 speed already and i have been told that this will bolt up to a 1jz.
Any info on this will be fantastic....
go 2jz if ya do it
Gerald
ta22 Green with cream vinyl roof, 2t/3t hybrid with a few go fast bits on + 5 speed.
Mate the conversion has been done have a search on boostcruising. The getrag won't just "bolt up" as far as I know so you will need an adaptor plate for your bellhousing or just get a front cut that has an R154 already attached and ready to go. Probably not the easiest coversion to start off with if you're doing it yourself.
Well well well, something good does come out of that site...
I cant help, but good luck with the conversion ive seen a few sr20 and 13b conversions on these cars, a 1j would be quiet unique in many aspects.
Speak to BenTT on here or supraforums.com.au he has done a few BMW 1jz conversions
If in doubt power out
The Getrag that bolts to the 1JZ is the V160. It has a custom bellhousing made to suit the 1JZ/2JZ blocks and is not removable from the gearbox.
Graham D
Lexus RX350 (no mods yet !!!)
Lexus IS200 / 2.5GT-T (1JZGTE VVTi + Getrag 6 Speed)
Lexus IS200 (wife's car and no mods allowed !!!)
Suzuki GSX750-F
Be carefull when it comes to the control modules etc? alot speak to the DME (Digital Motor Electronics) for example ABS Control Module and ATC (Traction Control) Control Module, it may/will store faults if it doesnt see a DME, im not sure how people tippy toe around those things. Just a heads up
O i work at BMW, im not some "know it all" looser lol.
E34 will probably require a custom inlet manifold, modified sump (depending on where you sit the engine), custom mounts (both gearbox and engine), custom tailshaft, adaption to BMW radiator, etc, custom dump pipe, you will most likely loose a lot of the OBC controls, unless you have the OBC where you can calibrate it to suit.
My Garage:- www.cardomain.com/id/bmwturbo
wow, didnt expect this many replies, anyway.
My e34 does not have abs or traction control, so things should be all good there.
i will only need custom engine mounts if i use my getrag box but yes i will need dump pipe radiator, im also pretty sure the sump will not need modifying.
But why custom inlet manifold.
And why is the bell housing not removeable from the v160.
Pretty sure it's all cast as one piece.
Stan - It is cast with the front portion of the gearbox. To change it is a major exercise in welding - in fact almost impossible. But your box is a 5 speed version of the Getrag so may be different.
Graham D
Suzuki GSX750-F
Wow one of the first aye, nice and easy then, considering the electrical side anywayOriginally Posted by stan
ha ha yeah i pretty much got the electrics sorted, I THINK....![]()
As for the bowx if mine does not mate up i guess i will just get a custom bellhousing.
It should fit with no dramas as i have just browsed and seen a 7 series with one a 5 series with one and even a three series too, hopefully all will be good....
Does any one have some 1jz soarer ecu wiring diagrams they can share with me...
I didn't know so many people did BMW conversions, My hats off to them and to you of course. Good luck with the conversion anyway, if you step into any BMW Problems let me know, ill be able to help you out no worries
+Rep for the thread too
hey adrian thanks.
I do have a question can you fix a cracked m20 bmw head if it cracked from front to back...
hehehehehe...
