if u've got the stock ECU, and u've got the stock motor, u won't need any of that avcr, safc etc etc...
but if u wanna go for a big single, u'll be going for a whole different ballgame.. in which case, if u're chasing high horses, u'll need bigger injectors, fpr, aftermarket ecu etc etc
erm.. don't u get the stock turbos with the front cut?? erm.. also does ur cross-member fit it or u'll need a different sump to clear the cross-member??
only thing i can see u'll need is a fuel pump that can support the 2JZ (a simple walbro GSS342 comes to mind, or bosch 040).. and yea fuel lines etc etc...
and if it's ur first, i'd suggest get it running stock first, then build it up later on so this way at least u have a basis to start on... and it'll run... who knows u might be happy with it the way it is? keep in mind u'll be running a big motor in a car that's lighter than what it came with
