Results 46 to 60 of 63
Thread: Power steering too light.. how to fix??
  1. #46
    Junior Member Automotive Encyclopaedia Nim's Avatar
    Default Re: Power steering too light.. how to fix??
    Quote Originally Posted by Bowlsclubboy
    On my jzx81 rack, i if i disconnect the steering black box, the wheel gets hard to turn....really hard lol
    The speed sensitive steering could be a hinderance while drifting as you could be doing 60km.h in a straight line but your speed sensor is reading the wheels as doing 160km/h and therefore makes the wheel stiff and hard to flick.
    I might have to get one of those jaycar gizmos.
    Even if it's stiff it should be okay to flick. It'll give you better feedback anyway, which I imagine you want when you're drifting. I was under the impression that 'flicking' wasn't really what you want to do in a drift anyway? I allways heard that to do it properly, you don't turn the wheel as much? Anyway, that's getting a bit OT.
  2. #47
    Cressyskidder Grease Monkey Bowlsclubboy's Avatar
    Albury NSW
    Well, put it this way, i didn't enjoy driving it with such heavy steering lol.
    1992 MX83 Cressida Grande-1JZ-GTE...Actively Dori.
  3. #48
    Junior Member Domestic Engineer urantia's Avatar
    I just got my progressive power steering wired up and functioning. I had gotten used to no PS on the supra for a few weeks and it wasn't all bad, you got used to it. But now having the PS again makes the car feel really lite, as if 500KG has just been taken off the front wheels. I like it. It's also a nice change from the previous PS i had on the 7mgte which was always on, no feel at high speed.
  4. #49
    I have a controller, yes....
    .... however one is unbuilt and the other has the wrong PICs in it (built as boost controller kit).
    Ed, you will need to be contacting me
    ...... butt scratcher?!
  5. #50
    Junior Member Grease Monkey Bored?'s Avatar
    Any follow up on this thread? Did you guys actually end up trying to adjust the PWM signal eventually?
  6. #51
    Did any of you guys end up doing this, or been too busy with other stuff?
  7. #52
    Teh Massif Dong Carport Converter BlackSupra's Avatar
    enlighten me phyiscs gurus, but i have extremely long PS hoses in my car, by shortening the length of the hoses in a more direct fashion and reducing the overall volume capacity of the PS system, what effect will this have on the feel of the steering?
  8. #53
    Western Aus
    technically there shouldnt be any difference, once the pipes are filled (and all air is out), given the fact that the lines wont expand and contract any with the pressure, it should be much the same, as the pump and rack have to move the same amount of fluid.
  9. #54
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Instead of starting another thread, I thought I'd ask here.
    Is there a separate "ECU" for the PPS on a JZX81, or is it an ECU output? Where is it if it's separate? I'm using the rack in my MX83 conversion.
  10. #55
    Junior Member Backyard Mechanic TC1600's Avatar
    Feb 2007
    Quote Originally Posted by BlackSupra
    Would make no difference, in the same way that a bigger sump does not affect engine oil pressure. It's about flow rate, not capacity.
  11. #56
    Junior Member Backyard Mechanic pisso001's Avatar
    Dec 2006
    Ed - What actually made the difference? Was it the extra caster or the PPS loom unpluged? I guess the second..
    I sorta have the same problem with my RT142. Havent tried adding caster yet but if that doesnt work would this gizmo work for me? Or can you just adjust that valve that 'CrUZida' was talking about..
    Thanks,
    Chris.
  12. #57
    Western Aus
    Quote Originally Posted by Gavatron
    since JZX81 is nearly identical to JZA70, id say, like the JZA70, there will be a separate PPS control box.
    AFAIK everythings still in the loom, the only thing that needs attaching when doing the conversion is the radiators temp sensor.
  13. #58
    Quote Originally Posted by pisso001
    I doubt the RT142 has the PPS valve that I spoke of.
    You'll have to do something mechanical or hydraulic to slow it down.
  14. #59
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    The PPS ecu is mounted to right of the steering column on a Z20 & A70 chassis, little box with inputs from a steering sensor on the column, speed input & rpm input too (i think)
    I've rigged mine up with a switchable 0 or 12v supply on my Z20 drift car direct to one wire on the rack, 12v is super light for manouvering & parking, the 0v is heavy but ideal for dori action
    Sliding his D1 Soarer around the UK
  15. #60
    Dec 2006
    I wonder if i could rig up something simliar to 'cptsideways' on my corona..
    If i were to put a pully on the power steering pump with a switchable cluch like Aircon and Supercharger pullys, then id be able to have power steering for steet use and when im on the track switch it off.. Would that work?
    Thanks,
    Chris.
  1. RA2x steering box tech Q's
    By Gleno28 in forum Tech and Conversions
    Last Post: 04-07-2006, 11:17 PM
  2. Power steering idle-up valve
    By Rattlehead in forum Tech and Conversions
    Last Post: 29-12-2005, 08:58 AM
  3. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 28-12-2005, 11:52 PM
