what do you mean by loosness ie what does the car do?
rca's dont give neg camber they just lower your balljoint hieght and depending on wher your lca was in its arc will determine which wether you increase or decrease camber but it only changes by less than 0.5deg in most cases.
more camber can give increased turn in , and let you drive faster through a given corner dependin on tyre choice but in saying that you can also have too much and this will give you the opposite affect because too little of the tyre is in contact with the road.
the right amount of camber for a certain car is mostly dependant on the tyre you use.
large amounts of static camber can destroy tyres quickly and has alot to do with toe settings as well.
my advice is take it to a susp specialist and get them to look at it, ( and i dont mean KMART Tyre and Auto)
hope that helps
