Alot of work for the improvment.... its not a straight swap.. but can be done easy enough if your half good with cars...
For example : the pedal box from yours needs to be mounted in the donor car, holes drilled etc. not sure with the sv21, but the ecu might crack the shits and not run or run poorly.
Many have been done on here, have a bit of a search and youll get the basic idea from other model cars.
It will be easier to just go buy a 2nd hand auto from the wreckers for a 100 dollars.
Good Luck.
