Results 1 to 3 of 3
Thread: 1jz plugs
    sir Grease Monkey
    tasmania
    Default 1jz plugs
    hey guys ,ive got onto a set of laser irridum plugs and the part no is for a typhoon falcon . on the ngk chart these plugs will suit a 2jzgte , so do youz rekon they would be allright in my 1jz . the part no is ifr6t-11. cheers big wad.
    Default Re: 1jz plugs
    Most people have found that copper plugs work just as well if not better but have to be changed more often. bkr6e or bcpr6e gapped to .8mm is what most people use. Go to a 7 heat rating if you have mild mods.
    QUICKEST 1JZ'S IN OZ
    Western Aus
    BKR6E gapped to .7mm is what i have, gapped at .8mm started to miss above 1-1.1 BAR of boost. it depends on what condition your coilpacks are in, but yeah, the fancy expensive spark plugs arent worth the money.
    Elmo.
  1. 1JZ performance head build. Advice/help?
    By ReQuieM in forum Tech and Conversions
    Last Post: 09-07-2007, 09:08 PM
  2. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
