Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 106
Thread: 1JZ / 2JZ into MA61 / MZ10 Guide.
  1. #61
    Default Re: 1JZ / 2JZ into MA61 / MZ10 Guide.
    Quote Originally Posted by auto351 View Post
    Can some one tell me what 2JZ its from
    Looks like Aristo, JZS147.
    GTE or GE?
    Wilbo's JZA80
    Wilbo's JZZ12
  2. #62
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    its just the GE version.
    Ill have a look around for a wire diagram for JZS147
    thanks.
    Edit
    Found this link http://www.jzs147.com.au/forum/viewtopic.php?t=7799
    its the same plug but not much info.
  3. #63
    I think madmont posted some in the wiring diagram thread see if you can't find them.
    Otherwise I have the jdm jzs147 wiring book that I got off madmont (thanks!) So if you get stuck should be able to help
    Wilbo's JZA80
    Wilbo's JZZ12
  4. #64
    May 2010
    Moscow
    auto351
    As a matter of good practice you would include ECU cat.# in your post. The number is found on top ECU lid, it starts from 89661. This would save lots of time spend on guessing otherwise.
    Generally, connectors look like mfg. date is way earlier 1995. So I would assume jzx90, jzs14..
  5. #65
    West Australia
    Guys
    I might be doing this shortly.
    Ive got JZA70R 1JZ from my Z20
    Converting it to front sump
    getting Bonnieville mounts
    I need to know if those custom dumps on the previous page work or not... as my engine has them.
    does anyone know?
    Also the shell im getting is 5MGE+W58 fitted, What needs to be done regarding the tailshaft and gearbox Xmember to fit my 1JZ+R154 in....
    i see on the 2nd page someone mentions if the MA61 was "AUTO" that you can use that gearbox xmember, but this one is manual...
    in summary:
    Tailshaft mods when going from 5MGE+W58 to using 1JZ+ R154 (WHATS NEEDED TO BE DONE)?
    Do the custom dumps on previous page fit, or do they hit the steering arm to the rack?
    Can i use the W58 gearbox xmember to mount my R154 in after i "massage" the tunnel with a mallot?
  6. #66
    Quote Originally Posted by Admiral coFF33 View Post
    No you can't use the W58 gbox xmember, but an auto MA61 one will work
    Wilbo's JZA80
    Wilbo's JZZ12
  7. #67
    West Australia
    uhhh, any other comments on the questions i posed wilbo ?!
    cmon man!
  8. #68
    Tailshaft will need mods.
    Both in its length, and its yoke.
  9. #69
    West Australia
    do i keep MA61 shaft or JZA70/z20 shaft.?
  10. #70
    Guys
    does anyone know?
    in summary:
    i have no input into what needs to be done... but just wanna say... FUCKING SICK...i highly condone a 1j/z10 combo...
    Stomps
  11. #71
    Use the MA61 shaft, and have the JZA70 yoke/uni welded onto it.
  12. #72
    West Australia
    so JZA70 front bit of shaft + yoke /uni ... welded onto the MA61/z10 shaft.
  13. #73
    Pretty much yep.
    Take both shafts to them, and say I need this welded to this, and it needs to be this long...
  14. #74
    West Australia
    hrrmmm
    so now i will hunt hard core on toymods for how long it needs to be
  15. #75
    hrrmmm
    I'm pretty sure that I've answered that before, check. my posts, I think I have one with pics of each gbox
    Wilbo's JZA80
    Wilbo's JZZ12
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
