you just plugging up holes with sensors that were otherwise plugged by plugs.
I say, nothing wrong and a handy find.
Hey guys, I've had a search but have not found anything on this.
On the side of the 3SGE / GTE (they're the same as far as i can tell) Gen 3 oil pump there are a 3 plugged up channels.
I've worked out that No. 1 is connected to the outer part of the oil filter mount, and that No. 2 and 3 connect to the inner threaded part of the oil filter mount. I'm guessing they were put there to allow a factory fitted oil cooler to be attached to the engine?
(highly scientific method)
What I'd like to know is if i could connect up the senders for my oil temperature and pressure gauges to these openings? Conveniently, my oil temperature sender is a perfect fit and it shouldn't be hard to get an adaptor for the pressure sender.
Do any of you more-smarter-than-me people see a problem with doing this? Or is it all systems go?
The pressure sender is quite bulky and i may have to mount it remotely with a short piece of braided line - the fitting may fatigue and snap over time due to the vibration. I dont think it'll physically fit down there anyway. Does the pressure gauge specifically have to be connected to the outer part of the filter or does it not make a difference?
I'd hope this will work because it'll save me $60 on an oil filter sandwich plate!
Thanks guys,
Andy.
[Project] 'Bugger' - 1999 Toyota Hilux Turbo Ute - PB: [email protected] 1.857 60FT Video
[Project] 'Red Baron' - 1990 Toyota Celica GT-Four - PB: [email protected] 1.869 60Ft Video
Technical Articles Database 3S-GTE/ST185/Celica - BGB,EPC,Tech || 2RZ/3RZ/5VZ/Hilux - FSM
No probs doing that. Just make sure you mount the oil pressure sensor correctly. When i say that, if you are using one of those bulky pressure sensors (AutoGuage as an example) do not use a brass adapter as they will snap over time leading to a very large oil leak and quite likely oil starvation. Use a stainless adapter and if possible some braided line and mount the sensor to a bracket.
Regards,
Ivan
thats fine but fit the oil temp in to the steel sump ,as that will give you a better idea of what your oil temp will be
