Results 16 to 30 of 40
Thread: 1JZ VVTI upgrade turbo - HELP
    Default Re: 1JZ VVTI upgrade turbo - HELP
    High flow what part of the turbo? If compressor wheel which I would expect then from what size to what size. what trim wheel do they use?
    QUICKEST 1JZ'S IN OZ
    Forum Sponsor Conversion King
    Dec 2006
    make sure they use the correct hole size in the front wheel not a sleeve to make a larger wheel fit.
    ive had balance problems before not allowing the turbo to spin hard enough to give the desired amount of airflow and pressue.
    Jan 2007
    Quote Originally Posted by bm1jz
    These are the specifications:
    (1) High Flow the Turbo
    (2) Replace ceramic wheel with a steel wheel.
    (3) Change all seals, O Rings and perform a complete rebuild.
    I Spoke to Mike. He was really helpfull.
    Any more on this matey ? This would be alot cheaper than me buying a GT3037 Kit from Japan.
    Junior Member Grease Monkey markiitourerv's Avatar
    south australia
    I am keen also, am looking in to this at the moment.
    Jan 2007
    I really dont want/need more then 250RWKW, but the thing that worries me about hi flow is the loss of response.
    May 2007
    Hey Guys,
    I didn't end up hi flowing the turbo as it it didn't really allow for future upgrades/modifications. I have now got a custom manifold made up and am running a GT3040r with external wastegate. All the stainless steel work has been done now, thanx to 1JZracing. Just a matter of a few more little adjustments here and there before i put her on the dyno.
    south australia
    The response issue shouldn't be as much of a problem as it is with other motors.
    Toymods Club Member Grease Monkey scrote's Avatar
    am looking into an upgrade soon also. what was the price comparison for the two. i spoke too gcg and they told me around 2k for the turbo rebuild etc etc.
    Dec 2006
    call precision turbos in wetherill park and see what they can do for you. 2k is a bit steep in my opinion and you would be better off getting a b/b garret for those kinds of dollars.
    better not cut up that dump pipe cause its too nice to destroy
    linden
    lol.
    yeah think i might just be better off getting a gt30 and getting it done properly.
    Dec 2006
    but is it worth the extra $$$, you could get a steelwheel and larger comp wheel put in for around 1200 and bolt everything back together or spend 2200turbo, 600gate, 600+mani then still have to do cooler pipe + intake + lines + dump.
    how much do you want to spend and how much power do you want to make?
    linden
    linden
    600 bucks for this manifold youre going to make me huh?
    Dec 2006
    no that would be a base price that ive seen some go for. didn't you notice the +
    you could get a slappy for that price but if its not designed well it could ruin all the other hard work.
    linden
    Toyin around the Yota
    May 2007
    OH
    Just wondering if there was any good off the shelf manifold available, or are they all custom.
    It seems that HKS/greddy/blitz may sell them as part of their kit, but cost without?
    Also how much difference is there between the 2jz and older 1jz manifold?
    Thanks for any help
    Jan 2007
    Tomei make a nice Stainless manifold for about $700 plus shipping. Check Yahoo japan auctions.
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 12:06 PM
  2. 3sgte Turbo Upgrade - WRX turbo?
    By medwin46 in forum Tech and Conversions
    Last Post: 25-11-2006, 07:02 PM
