Results 1 to 6 of 6
Thread: fuel pump fuse
    no backyard Domestic Engineer japlish's Avatar
    Default fuel pump fuse
    hey all,
    just wondering if anyone has an idea whats goin on with my car,
    i have a ae71 with ae92 4agze in it, its got the standard ECU for it and i run a standard fuel tank with a surge tank in the boot with some type of lift pump and high pressure pump (they came with the engine when i bought it) i just replaced the fuel cell with the standard fuel tank on friday and i was goin for a strap yesterday and was goin ok for about 1/2 hour then it stalled, found that it was the fuel pump fuse and replaced it. started it again got 100m down the road then it blew again, replaced it with a bigger one and it did the same thing! whats goin on? are my pumps dieing and drawing too much current or what?
    Default Re: fuel pump fuse
    I blew a fuel pump fuse while attempting to drift at calder park a while ago, but i'm not running a surge tank so i figured i starved the pump.
    i put in a 20 amp fuse in place of the 10 amp one i had, it could be as simple as not having the right fuse (but don't just jam a huge fuse in, the fuse is there for a good reason!)
    was it a hot day? how is your surge tank set up? if your main pump is getting hot fuel or no fuel then it could cause problems.
    it did have a 15 amp fuse in there in the first place then i changed it to a 20 amp it it blew it too.
    it wasnt that hot yesterday either
    i have the low pressure pump connected to the pick up line inside the tank then it feeds the surge tank i dont think the lines are getting pinched when it goes under the boot floor to the tank so i dont THINK its that.
    Montrose
    Sure you haven't just squished a wire somewhere...
    do u have any particular wire in mind?
    apprentice pwnerer Grease Monkey phrostbyte's Avatar
    The positive wire to the pump that would cause the fuse to blow?
    RIP Kev. You'll be missed.
    Old worklog of the last 2 KE70s (long since updated): http://ke70.theicy.net/
    Current AE71 4AGE Daily Driver (Soon to undergo AE86 front end and rear bumper!!: [COLOR=Blue][url]http://www.toymods.net
  1. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 10:49 AM
  2. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
  3. GZE cutting out after 5 PSI ***NOW with Fuel Pump question***
    By old_mr2 in forum Tech and Conversions
    Last Post: 21-12-2005, 11:29 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
