Results 1 to 15 of 19
Thread: xM Series Engine Variants
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default xM Series Engine Variants
    Engine model and generation:
    MA70 Supra 7M-GTE gen 1
    (In an MA61)
    Top End Modifications:
    Retorqued standard headgasket to 72 ft/lbs
    New valve springs and reco'ed head
    Bottom end modifications:
    None - Stock Internals
    Forced induction:
    Turbo-A CT26E Highflowed
    Running 13psi via GFB bleed valve
    Management:
    Stock Factory ECU
    Apexi SAFC II
    Stock AFM
    550cc RC Engineering Injectors
    Stock Fuel pressure Reg
    Stock 5ME fuel pump!
    Fuel used
    BP Ultimate
    Intake:
    600x300x76mm Ebay Front mount Intercooler with 2.5" aluminium flowed pipework
    Cold air induction (in guard) with K&N filter
    Exhaust:
    3" Mild Steel Dump pipe and exhaust
    High-flow Cat
    Driveline:
    244mm 7M-GTE flywheel redrilled and dowelled
    Heavy Duty clutch
    W58 Supra 5 Speed
    Truetrac 3.9:1 LSD
    Default Re: xM Series Engine Variants
    MA70 Supra 7M-GTE Block and I think NA Head (ported to buggery)
    Ported Head
    HKS 1.2mm MHG
    10.7:1 Comp Pistons
    Balanced bottom end
    Management:
    Microtech LT10s ECU
    Fuel used
    BP Ultimate 98 Octane
    Intake:
    Mustang Cobra Twin 57mm Throttle mated to cut down stock Y piece manifold.
    80mm inlet pipe with generic pod
    Exhaust:
    FGK Tuned Length Extractors
    Unkown Cat
    2.5 inch mandrel bent mild steel exhaust into a Lukey Muffler
    Driveline:
    Heavy Duty clutch
    W58 (JZA80) Supra 5 Speed
    Standard clutch pack 3.9:1 LSD
    If in doubt power out
    SO00RA Domestic Engineer 4agerolla's Avatar
    7M-GTE (1988, unsure of series) in MZ21
    None
    None
    Forced induction:
    Stock CT26
    Running 10psi via bleed valve (soon to be ebc)
    Management:
    Stock Factory ECU
    Fuel used
    BP Ultimate
    Intake:
    HKS filter
    Exhaust:
    3" From turbo-back
    Driveline:
    Stock Auto
    Supra 3.9:1 LSD
    - Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
    - Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
    - Blue KE17 Sprinter- 3k + K40 manual
    - White MS55 Crown - 2M + 4 speed column shift manual
    - Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
    JZA80 Convert Backyard Mechanic
    7M-GTE(not sure of year, late series, grey plugs) in MA61
    HKS 3mm MHG
    Stock headbolts torqued to 72ft/lb
    None
    Forced induction:
    Stock CT26
    Running 11psi via bleed valve
    Management:
    Stock Factory ECU
    Fuel used
    BP Ultimate
    Intake:
    K&N filter 1g-gte intercooler(I know it's too small!)
    Exhaust:
    3" turbo-back, high-flow cat
    Driveline:
    Standard W58 with brass button clutch
    Standard 3.9:1 LSD
    7M-GTE in Ma70 (not sure of year of motor)
    Cometic 2mm MHG
    ARP head studs
    None
    Forced induction:
    Trust td-06 (old one)
    Running 13psi via bleed valve
    Management:
    Stock Factory ECU
    Fuel used
    BP Ultimate
    Intake:
    K&N filter, Turbo A intercooler
    Exhaust:
    3" turbo-back, no cat
    Driveline:
    Standard R154 with slipping clutch
    Jza70r 4.11 LSD
    Same motor and setup made 278rwhp on 12 psi with standard ct26
    MA61 Supra 5M-E (2.8L, SOHC, inline 6)
    Management:
    Stock Factory ECU
    Stock AFM (adjusted a bit leaner)
    Fuel
    Walbro GSS-341 (255 l/hr)
    Intake:
    K&N pod filter, no box (soon to be new filter and CAI)
    Exhaust:
    2 1/4" exhaust
    No Cat and lovin' it
    Driveline:
    Stock flywheel
    Xtreme Heavy Duty clutch kit (still on the mild end of the scale)
    W58 Supra 5 Speed
    Stock good ole clunky 3.909:1 LSD
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    MS65 Crown - 4M early type
    Leaking rocker cover gasket, blue oil cap
    Carbon buildup Hi-Comp pistons
    Management:
    Stock 2 barrel carby with 5M-E electronic ignition
    Fuel used:
    92 RON
    Intake:
    Yes
    Exhaust:
    2.25" from standard manifold back
    Driveline:
    ToyoGlide™ with busted torque converter (see power curve)
    Forum Contributor Domestic Engineer
    MA71 7MGTE- unsure as to gen, 12/88 model
    Nil
    Nil
    Management:
    Stock
    Fuel used:
    98RON
    Intake:
    Stock air box and filter, with front cut out of air box cold air feed, Std cooler and pipework, aftermarket ( non leaking ) BOV
    Exhaust:
    2.75" divorced dump pipe, with waste pipe joining about 18" down stream, 3" system with cat and non straight through muffler
    Driveline:
    R154 man, excedy HD press plate with organic disk
    http://img5.uploadhouse.com/fileuplo...acf6b411b8.jpg
    http://img7.uploadhouse.com/fileuplo...8960643ac9.jpg
    SignWriter Grease Monkey MZ20's Avatar
    7MGTE (86)
    Rebuilt head to stock spec
    No knock!!
    Management:
    stock ECU
    Fuel used:
    98 RON
    Intake:
    AFM - dodgyer than stock ic piping (gaping hole after afm) and stock cooler
    T-70 turbo - HKS Mani
    Exhaust:
    3" from turbo - metal cat - 2.5" tailpipe - stock muffler
    Driveline:
    A340
    The dyno vid:
    http://www.youtube.com/watch?v=e4dJcjHCTi0
    89 ma70 Supra
    7mgte :
    stock bottom end
    stock head gasket!
    Turbo"A" ct26 turbo
    denso 550 injectors
    3inch turbo back
    2.5 intercooler pipes
    frontmount cooler
    SAFC 2
    @14psi
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    MZ20 7MGTE in MX83 Cressida
    Forced induction:
    Hi-flowed TOM's turbo
    Boost controlled at 17psi by E-Boost2
    Management:
    Microtech LT10s - no afm!
    550cc RX7 injectors
    Sard FPR
    Bosch 040 feeding surge and Bosch 044 feeding rail
    Fuel used
    BP Ultimate
    Intake:
    600x300x76mm Ebay Front mount Intercooler with 2.25" stainless pipework
    Pod from workshop floor
    Exhaust:
    3" stainless from turbo back
    Driveline:
    Stock clutch out of halfcut
    R154 box
    JXZ81 LSD 4.1?
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Aug 2006
    *double post*
    Nil
    Nil
    Management:
    Adaptronic with ECU controlled boost
    Fuel used:
    98RON
    Forced Induction:
    Stock CT26 with 12 PSI
    Intake:
    Enclosed pod filter, with cold air feed, Group A supra cooler and 2.5" pipework, aftermarket ( non leaking ) BOV
    Exhaust:
    2.75" divorced dump pipe, with wastegate pipe joining about 18" down stream, 3" system with cat and non straight through muffler
    Driveline:
    Pink= as per previous post (std ECU and cooler) with 11PSI via celicamad / hyperboost controller.
    Green= as above (adaptronic and Group A cooler) with hyperboost controller & 12PSI
    Red= as above with adaptronic controlling boost @12PSI
    Green= as per last graph red line
    Red= highflow CT26 @12PSI
    Mar 2008
    inner west syd now!
    MA61 5m-ge, first gen, no TCCS
    none
    none
    Management:
    Standard 5mge
    Fuel used
    Unleaded, no knock sensor
    Intake:
    K&N pod filter
    3" stainless steel intake, AFM-TB
    Exhaust:
    unknown Extractors
    Cat-less 2.5"
    cannon muffler, also unknown
    Driveline:
    Heavy Duty clutch
    W57
    standard worn to buggery LSD
    1971 4M
    Custom cam grind, port and polish
    Custom 83mm Forged pistons at 10:1 Compression
    7M-GE crank and Rods
    Modified 5M-E Crank pulley
    5M-E Electronic Dizzy
    Hand formed additional oil feed to the head
    7M-GE oil pump
    Management:
    Twin downdraft weber Carbies on factory Twin carb manifold
    Fuel used:
    BP Ultimate - 98 Octane
    Exhaust:
    Extractors and 2.5" Sports Exhaust
    Driveline:
    Factory 3spd Auto and 4.1 F series Live axel diff
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 12:51 PM
