Results 1 to 15 of 19
Thread: xG- engine variants
    Default xG- engine variants
    Engine model and generation:
    GA70 Supra Gen 3 1G-GTE Manual
    Top End Modifications:
    None - Stock
    Bottom end modifications:
    None - Stock Internals
    Forced induction:
    Stock Turbos running 1.1 bar boost
    Apexi AVC-R Boost Controller
    Management:
    Stock Factory ECU
    Stock AFM
    Stock Injectors
    Stock Fuel pressure Reg
    Fuel used
    BP Ultimate 98 Octane
    Intake:
    Port Matched Intake pipes
    Front mount Intercooler with 2.5" pipework
    MX83 Cressida Airbox with K&N filter
    Exhaust:
    3" Stainless Steel Hi flow side exiting exhaust
    Driveline:
    TRD 825kg Pressure plate
    Clutch Industries 4 Puck button Clutch
    W57 Supra 5 Speed
    Hilux Diff - 3.7:1 Ratio LSD
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Junior Member Grease Monkey Screaminrolla's Avatar
    Default Re: xG- engine variants
    Stock
    Stock Internals
    Forced induction:
    Custom Manifold
    GT3082R
    Gizmo Boost Controller
    Management:
    Microtech LTX12
    440cc Injectors
    Fuel used:
    Intake:
    Front mount Intercooler with 3" pipework
    K&N pod filter
    XF Falcon Throtle Body
    Exhaust:
    3" Stainless Steel
    Driveline:
    Exedy Heavy Duty Button
    W58 Supra 5 Speed
    Hilux Diff - 4.3:1 Ratio LSD
    1977 RA28 Celica 1JZGTEClick Me
    1980 Chrysler Sigma
    GEN III 1GGTE from GX81
    Standard
    Standard
    Forced induction:
    Standard @ 15psi
    Management:
    Standard Manual ECU
    Standard injectors
    Standard AFM
    Home made boost controller
    Sard FPR
    Fuel used
    Optimax
    Intake:
    K&N pod filter
    Ebay intercooler
    Exhaust:
    3" from the turbos
    Driveline:
    w58
    Exedy clutch
    Standard RT142 diff
    Truetrac LSD
    Late model 1G-GZE Manual 8.0:1 compression ratio
    Adjustable Cam Gears Only
    Stock Internals
    Forced induction:
    Custom Steam Pipe Manifolds
    2 x T25g's (ex SR20 red top) @ 21psi
    Greddy Profec B Spec II
    Management:
    Microtech LTX12s with 3 Bar Map sensor
    440cc Injectors
    Duel Feed fuel rail
    Fuel used:
    Intake:
    2 x 3" Pod filters
    XF Falcon Throttle Body
    Exhaust:
    2.5" Dump pipes
    3" Mild Steel system
    Driveline:
    Race clutch custom unit (1050kg BMW M3 Pressure plate, 5 puck Carbon friction plate)
    W57 Supra 5 Speed
    Stock Locked - 4.11:1 Ratio (F292 IRS)
    CHECK IT OUT HERE
    Gen 1 1GGTE
    Stock
    Stock
    Forced induction:
    T70 Turbo running 24psi
    Turbosmart T boost
    Management:
    Microtech LTX12s
    440cc Injectors
    Fuel used:
    Intake:
    5" Pod filter
    Custom plenum on stock runners
    Exhaust:
    3" Mild Steel
    Driveline:
    Exedy HHD
    W58 Supra 5 Speed
    Hilux 4.3 LSD
    KE38 - 2TG
    MS65 - 1UZ
    [IMG][/IMG]
    Gen 3 motor,...gen 2 ecu/inj/Tb
    None - Stock
    Forced induction:
    garrett BB gt3071r, custom 6BOOST manifold
    46mm, EBAY external wastegate
    running 12PSI
    Management:
    ALL factory GEN 2 ecu gear, afm/inj/TB
    Fuel used
    PULP
    Intake:
    $15 pod filter.
    front mount HYBRID cooler
    2 1/4 and 2 1/2 cooler piping
    Exhaust:
    custom 6BOOST manifold, ext gate
    3" mandrel dump,,..
    mandrel bent into Y pipe, splits into twin 2 1/4 hotdogs then 2 1/2 twin side pipes (one out each side
    Driveline:
    excedy HD kit
    w5X box
    Volvo 240 rear
    TRU TRACK lsd, with 3.73:1
    Engine model and generation: 1G-GTE Gen 3
    Top End Modifications: None
    Bottom end modifications: None
    Forced induction: Garett T04E
    Custom ally piping.
    Turbosmart dual stage boost controller 10/18 psi
    Management: EMS
    440cc Injectors,
    Bosch 040 internal fuel pump.
    Coil packs
    Fuel used BP Ultimate 98
    Intake: Custom intake.
    Front mount Intercooler.
    K&N Filter.
    Exhaust: 3 inch all the way.
    Driveline: Exedy 5 puck brass button clutch.
    W58 Supra 5 speed box
    Custom 2 piece tail shaft
    R31/Vl disc brake rear end. Diff (4:11 gear ratios with lsd centre)
    Cheers, Greg.
    engine, 1ggte
    top end mods, reconditioned head
    bottom end mods, bored 20 thou je forged pistons, total seal gapless rings, rods and crank balanced
    forced induction, unknown turbonetics turbo, hks manifold and hks external wastegate
    management, microtech mtx8, ford falcon coil pack
    fuel, mobil 98, 440cc injectors sx fuel press reg
    intake, custom plenum been power ported, honda throttle body, cheap intercooler, k&n filter
    exhoust, 3 inch system with high flow cat, and muffler, and a hotdog
    driveline, w58 box, ceramic button 4 puck cluch with solid centre, hilux diff 4:3 lsd centre
    cheers steve,
    1ggte, 11.22 @122mph
    Gen III 1GGTE from GX81
    Standard
    Standard
    Forced induction:
    Twin Mitsubishi tD04-9b turbos @ 15psi
    Standard exhaust manifold with custom turbo adapters
    Custom stainless dump pipe
    Gizzmo boost controller
    Management:
    Standard Manual ECU
    Standard injectors
    Standard AFM
    Sard FPR
    Fuel used
    Shell premium unleaded
    Intake:
    1GGTE water to air intercooler
    Custom aluminium intake pipes
    Aluminium water reservior
    16" PWR heat exchanger
    Holden VS commodore air box
    Exhaust:
    3" system
    Driveline:
    W58
    Exedy extra extra heavy duty clutch kit
    G-series hilux diff 4.3 ratio
    Detroit truetrac LSD
    Additional comments
    running too rich!!
    User Conversion King
    NWA
    GX81 chaser Gen 3 1G-GTE Manual
    None - Stock
    Forced induction:
    Stock Turbos running 15psi boost
    Management:
    Stock Factory ECU
    Stock AFM
    Stock Injectors
    Fuel used
    Intake:
    600x300x76 chinese cooler
    2.25" IC piping
    Exhaust:
    2.5" press bent ghetto exhaust
    Driveline:
    PBR HD clutch
    W58 Supra 5 Speed
    markII diff - 3.9:1 Ratio LSD
    1/4 mile;
    13.4s
    103mph
    weak
    hello
    custom dont come in a box Domestic Engineer toymotorsport's Avatar
    May 2006
    gz20 Soarer Gen 2 1G-GTE auto
    power
    120kw / 161hp atw
    Stock
    Stock Internals
    Forced induction:
    Boost Controller 12psi
    Management:
    stock ecu
    stock Injectors
    Fuel used:
    Intake:
    Front mount Intercooler with stock pipework
    pod filter
    Exhaust:
    2.5" press bent Steel
    Driveline:
    stock auto
    Engine model :
    1GGZE unknown gen
    A340 auto trans
    Power :
    208.4kw
    Top end mods :
    race ported head
    custom cams 9.2ml lift 250degrees duration @50thou
    adjustable cam gears
    hardend valve springs
    extrude honed inlet manifold, balance tube fitted & xf falcon 68ml throttle
    Bottom end mods :
    Stock internals
    gen 3 full counterweight crank
    shot peened rods and crank
    stock pistons machined out to clear cams
    extensive oil gallery mods
    Forced induction :
    xtr gcg custom built t3/t4 turbo
    to4e core front side is 58 minor 76.2 major 7 blade inside a .50 cover
    .86 rear stage 3 sierra wheel
    custom single turbo manifold
    40ml external wastegate
    3" dump
    BA XR8 air box and K&N filter
    450 x 300 x75 front mount 2.5" alloy pipework
    Boost set @ 7psi
    Engine management :
    Motec M48 ecu
    motec ignition expander
    660cc injectors
    twin feed fuel rail
    Sard fuel pressure regulator
    bosch 500hp pump
    surge tank
    pre pump
    Fuel used :
    BP ultimate 98 octane
    Exhaust :
    3" exhaust, 3" high flow cat, single 3" muffler
    Diff :
    HIlux RN40 4.3 gears tru trac lsd
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Standard Gen 3 1G-GZE Auto in GX81 Mark II
    None – Stock
    None – Stock
    Forced induction:
    Stock SC14
    Management:
    Stock everything
    Fuel used:
    98 Shell Optimax
    Intake:
    Stock everything
    Exhaust:
    Stock 1G-GZE GX81
    Driveline:
    Stock A340E
    Stock 4.3 non-LSD
    16x7.5 Aristo wheels with 225/55 tyres
    Additional Comments:
    This run was done in 3rd and hit the 180km/h speed cut (though slightly higher due to the tyres). Second run was attempted in 2nd but it would not stay in 2nd and decided to upshift, even in manual mode (must be something with GX81/MX83).
    It’s a bit rich too
    Built not Bought Grease Monkey Rosie's Avatar
    Engine model and generation: 1977 RA28 - 143kw
    Standard Gen 1 1G-GTE manual 5spd from gx71 Mark II (aparently)
    None – Stock
    None – Stock
    Forced induction:
    Stock twins @ 7psi
    Management:
    Stock everything
    gizzmo 2 ebc
    Fuel used:
    premium
    Intake:
    kN filter
    Exhaust:
    3'' side pipe
    Driveline:
    w sreies
    VR 3.7 LSD
    17x7 Custom wheels with 245/50 tyres
    This run was done in 3rd and went well over the 180 limit but had this 'boost/fuel cut' (at about 5000rpm shit house fluttery noise out exhaust) when we tried to boost it higher. Did about 8 runs trying to do different things - adjust afm spring and a few other useless ideas.
    Ran way too rich sub 9's for a bit here and there.
    143KW - was fairly happy being a 1986 gen 1 but would be way better if i could fuck this 'cut' off.
    1977 RA28 1GGTE - never ending project
    Cough 'yaris' Cough - don't ask.
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    guess i should add mine here
    Engine model and generation: Unsure
    1gge cams
    None – Stock
    Forced induction:
    Custom manifold
    HKS GT 2540 @ 19 psi
    Management:
    wolf 3d v4 - tuned by pbe dynotech
    Fuel Delivery:
    7mgte injectors
    Fuel used:
    vortex 98
    Intake:
    K&N Pod in custom cai
    2" stainless piping
    400x300x76 fmic
    Exhaust:
    3'' dump, going to 2x 2"pipes, no mufflers.
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
  1. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  2. MA70 --> JZA70 Conversion
  3. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 10:49 PM
