Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: xS- series engine Variants
    Aug 2011
    Default Re: xS- series engine Variants
    Engine: Gen II 3SGTE - ST185 Celica
    Head: Custom cams of unknown specs, ported and polished
    Block: Arias forged pistons, shot peened rods, knife edged crank, ARP rod bolts and head studs
    Turbo: Stock, flowing 10psi, top mount intercooler
    Management: Stock
    Fuel: BP Ultimate
    Plugs: NGK Iridium
    Aug 2012
    Engine model and generation:
    Gen3 3S-GTE
    BP Ultimate 98 fuel
    1.1 BAR (16psi) boost
    Top End Modifications:
    Stock Head and valves
    ARP Headstuds
    BC Single Valve Springs
    HKS 272 (RT091 and RT092) Cams. 10.4mm Inlet, 10.2mm Exhaust
    Bottom end modifications:
    Wiseco 9.0:1 87mm pistons
    Eagle conrods
    Toyota Head Gasket
    ARP Main Studs
    Forced induction:
    Stock CT20B turbo
    Stock intercooler
    Bailey BOV
    Management:
    Autronic SMC
    Tuned by Buzzard
    Fuel:
    BP Ultimate 98
    Intake:
    Stock manifold and throttle body
    Unifilter Ram Pod
    Fuel:
    Bosch 044 fuel pump
    10mm fuel rail
    Bosch 351 injectors
    Weber pressure regulator
    Exhaust:
    Stock manifold
    Custom 3" dump pipe
    Custom TES 2 3/4" exhaust system
    Power.pdf
    Torque.pdf
    Tasmania
    please delete, updated power level in the post below.
    1973 TA22
    Tasmania
    3sgte 2 litre.
    gt3582r on 6boost manifold, 50mm gate
    custom plenum and 2zz throttle body
    hks 264 cams, valve springs, cam gears and twin power ignition
    acl race series forgies and race bearings
    600x300 front mount, 2.5" alloy and stainless piping.
    3" mild and stainless exhaust, ballistic cat, custom resonator, apexi rear muffler
    arp bolts and studs
    stock crank, rods, valves and ports.
    307kw, 600nm atw, 23 psi @ 7000rpm
    1973 TA22
    Mar 2012
    1984 KE70
    Gen 3 3SGE
    GSC stage 1 268' cams (Honestly made no difference).
    Adjustable wheels
    GT3071r 0.64 T25 internal gate @ 22psi
    Rams horn style manifold (Steampipe)
    Custom intake manifold (to suit RWD)
    Stock 3SGE NA Gen 3 head, valves, springs etc
    SRP pistons
    ACL race bearings
    Cometic head gasket
    ARB head studs
    550cc EVO injectors
    Rising rate regulator
    Bosch 044 pump, stock 6mm / 4mm fuel lines
    3in Mandrel stainless exhaust with cat
    Razorback ECU
    Daewoo Lanos coilpacks
    Iridium 8EIX plugs
    VN commodore air box with K & N filter
    Chinese intercooler
    Made 307HP at wheels with ignition breakdown.
    At the drags, it did 11.7 @ 120mph with 195 street tyres but muffler unbolted. Weighed in at 1060kg + driver (60kg) with full tank of fuel and full street trim. I change at 7000 but cross the line at 7500 in 5th.
    Estimated 450hp at engine during that run (it has done 11s several times).
    Full boost around 4200
    Tried a GTX2867r, had to completely retune, and run 6psi more to make the same power as the 3071
    I have been through about 7 engines due to all sorts of reasons from cracked blocks to something sucking into the engine.
    In the middle of installing a forged turbo BEAMS motor for it.
    Gen 2 3SGTE:
    1mm oversize Ferrea valves with throat and bowl correction
    1zz shimless bucket conversion
    Brian Crower valve springs
    Brian Crower titanium retainers
    Wade 267 w/ 9.25mm lift camshafts (1569C profile)
    Adjustable cam gears
    Gen 1 3SGE side feed inlet manifold
    ATS Racing phenolic spacer
    ARP head studs
    Cometic 1mm MLS gasket
    5SFE crank, knife edged
    Eagle conrods
    CP 9:1 compression ratio stroker pistons
    ARP main studs, rod studs
    Gen 3 oil pump and sump
    Forced induction:
    6Boost turbo manifold
    HKS 3037S turbo
    Tial 38mm wastegate
    Management:
    Adaptronic Select
    1200cc ATS Racing top feed injectors
    ATS Racing top mount fuel rail
    Aeromotive 340lph fuel pump
    Aeromotive fuel pressure regulator
    Fuel used
    e85
    Intake:
    3" HKS Mushroom filter
    600x300x76mm intercooler
    Exhaust:
    3" exhaust from turbo back
    Screamer pipe
    Driveline:
    ST205 gearbox
    Xtreme chrome-moly lightweight flywheel
    Xtreme button clutch
    27.90s @ Esses Hillclimb
    Forum Contributor 1st year Apprentice robk's Avatar
    Feb 2010
    1990 JDM SW20 MR2 GT, Gen 2 3S-GTE, 2.0L
    Power output:
    - 386.2rwkw (518rwhp) @ 30psi on E85, on a Mainline dyno
    - 300.8rwkw (403rwhp) @ 24psi on 98 RON premium fuel, on a Mainline dyno
    Turbo and exhaust:
    - Garrett GTX3076R turbo, 0.82 A/R turbine
    - Full-Race exhaust manifold, 3 inch exhaust system
    - Tial 44mm external wastegate
    - 3 port MAC boost control solenoid (boost controlled by ECU, varying with ethanol concentration)
    Intercooling:
    - Frozen Boost 'Type 5' A2W intercooler core on top left of engine bay
    - Custom front-mount PWR heat exchanger for A2W intercooler system
    Intake:
    - RacerX side-feed intake manifold/plenum with phenolic spacer
    - Turbosmart plumb-back BOV
    - Plazmaclamps incorporated into piping for reliability
    - 60mm gen 3 throttle body (instead of the 55mm gen 2 throttle body)
    - K&N pod air filter
    Block and Head:
    - 2.0L gen 2 3S-GTE block
    - CP forged pistons, part number SC7450 (86.5mm), ~9.0:1 CR with a 1mm HG
    - Eagle rods
    - Ross-Tuffbond Metal Jacket harmonic balancer
    - ARP head studs and main studs
    - Gen 2 3S-GTE head (ported)
    - Cometic head gasket, part number C4314-040 (0.04", ie. 1mm)
    - Cam Tech staggered camshafts 265in/271ex
    - Intake (Cam Tech part number 421B) advertised duration 265 degrees (225 at 0.05" lift), 8.7mm lift
    - Exhaust (Cam Tech part number 439A) advertised duration 271 degrees (230 at 0.05" lift), 9.5mm lift
    - Fidanza adjustable cam gears
    - Brian Crower valve springs and retainers, stock valves
    - Shim-under-bucket conversion
    Fuel delivery:
    - Flex-fuel, using a Continental-style flex fuel sensor (50-150Hz = 0-100% ethanol)
    - RacerX fuel rail kit
    - Injector Dynamics ID2000 top-feed fuel injectors
    - Turbosmart 'FPR1200v2' fuel pressure regulator
    - E85-compatible Walbro in-tank fuel pump, part number F90000267
    - Upgraded fuel pump wiring with a new relay under the dash
    - AN-8 braided teflon fuel supply line, from pump to rail (removed standard hard line above tank for fuel supply)
    - AN-6 braided teflon fuel return line, until the hard line (retained standard hard line above tank for fuel return)
    - Speedflow AN-8 fuel filter with stainless steel mesh element
    Ignition System:
    - RacerX 1ZZ coil-on-plug conversion kit
    - Denso/Ford 'AGSP 22YE07' iridium spark plugs gapped to 0.5mm (0.02")
    Engine Management:
    - Adaptronic e1280s standalone ECU
    Last edited by robk; 23-11-2016 at 10:40 AM. Reason: More info and updated dyno result
    1990 SW20 MR2 with '5S-GTE'.
    418rwkw @ 32psi of boost on E85.
    289rwkw @ 20psi of boost on 98 RON.
  8. #38
    Time to bring this thread into the modern era!!!
    LETS GET SOME BEAMS!!!
    Note:
    - the RED line is with dual VVTi tuned
    - the BLUE line is before the vvti was working
    - torque figures are out, the dyno software looks like it hasnt been configured properly for torque.... but they are still relevant as a point of reference for vvti vs no vvti!!
    Gen5 3S-GE - Blacktop "BEAMS" dual VVTi
    SQ Engineering intake manifold
    4AGE Blacktop 20V 45mm quad throttle bodies
    70mm trumpets
    Stock
    Forced induction:
    None
    Management:
    Adaptronic E420c (black label)
    Fuel used
    98 Octane
    Intake:
    Uni-filter socks
    Exhaust:
    Factory exhaust headers with custom made secondaries
    2.25" mandrel bent
    200 cell cat
    Resonator
    Redback muffler
    Driveline:
    Stock Clutch & Flywheel
    J160 6-speed gearbox
    ..otherwise stock
  9. #39
    Dec 2017
    south
    Quote Originally Posted by The Witzl View Post
    Note:
    70mm trumpets
    Stock
    Forced induction:
    None
    Management:
    Fuel used
    98 Octane
    Intake:
    Uni-filter socks
    Exhaust:
    2.25" mandrel bent
    200 cell cat
    Resonator
    Redback muffler
    Driveline:
    ..otherwise stock
    How did you get in excess of 300Nm of torque on this set up????
    Sent from my SM-G950F using Tapatalk
  1. sticky dyno results thread
    By chris davey in forum Toymods Car Club Membership and Feedback
    Last Post: 20-06-2007, 07:07 PM
  2. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
