Page 9 of 10 FirstFirst ... 78910 LastLast
Results 121 to 135 of 136
Thread: 1JZ ECU capacitor replacement info
  1. #121
    May 2010
    Moscow
    Default Re: 1JZ ECU capacitor replacement info
    I use Chinese noname (mfg.site http://tool-world.com/) CT-936, it costs around $70 USD here
    http://lib.chipdip.ru/125/DOC000125459.jpg
    I could once replace heater blower resistor using this iron so I assume it has enough power
  2. #122
    May 2008
    checked no dry solder joints... cannot be map sensor as other ecu works fine in the car
    1992 - JZA70 STOCK - SOLD
  3. #123
    Aug 2010
    Should be OK. I use and recommend Hakko irons.
    JZA70R_92, I was referring to the MAP/ AFM sensor electronics inside the ECU. As this circuit could be telling the micro in-correct air densities.
    Fast, Cheap, Reliable
    You can only ever have two..
  4. #124
    Nov 2011
    just get a desoldering station works the best
  5. #125
    May 2010
    Moscow
    Flex ok, and then could you tell me what temp/soldering tip do you prefer for this kinda job? Flat or round, what size?
    dumbass, I can't see any application for it other than replacing the caps on one or two ECU's...so unless I find the results of replacing the caps good enough, it would just sit on the shelf and consume free space
  6. #126
    Nov 2011
    hehe i used to do niztunes so i needed a desoldering station
    anyway use a flat soldering tip like a small flat blade screwdriver looking like tip
    and use the corner edge
    but u have to try not heat up
    i find the tiny pointy tips have useless heat
  7. #127
    May 2010
    Moscow
    Ok, very useful about the flat angled tip, gonna get one.
  8. #128
    Nov 2011
    If u goto nistune website then look t the instruction manuals for few of the nistune board installations
    It has good pics on the soldering iron tip and how to put it on the leg of the electrical piece
  9. #129
    May 2010
    Moscow
    Just been there, couldn't see a manual that deals with desoldering axial lead components. You only need to solder in some kinda connector and switch the board to external memory. There was quite helpful info on removing solder from free pads though
    p/s ok, manual for the type4 does have helpful info on iron tip
  10. #130
    Nov 2011
    yer the pics on how they remove solder from free pads
    u can see the type of soldering iron tip they use
    i never use electric irons
    just gas ones
    have 4 always in stock cause they fk up
    but im an expert at fixing them
  11. #131
    Chiba
    I use the Hakko desoldering station at work which makes short work of removing the caps, however a good iron and a solder sucker also works well.
    Some of them can be a bitch to remove due to the large pads acting as a heatsink, but a bit of perseverance will pay off.
    A trick to getting the caps out is to heat one leg and then with the iron still on the pad, rock the capacitor to lift that leg out of the hole. repeat back and forth between the two legs until it comes out (usually 3 or 4 goes) then use a solder sucker to clear out the holes.
  12. #132
    May 2010
    Moscow
    That's exactly how I remove em (if I have extra heat to warm inner layers enough). When at work, I would ask someone to put desoldering air gun nozzle against "tough" lead.
    I think my problem (when at home) is that I never tried any tips other than sharpened cone.
  13. #133
    May 2010
    Moscow
    p/s Did it. 100% success.
    1jz-ge, 5a/t , 1998
    2x 10uFx50
    2x 100x10
    2x 220x10
    1x 330x35
    replaced to Epcos of the same rating (NON-low-esr however, just good brand with stock availability). Immediately noted it greatly improved cold start. Not sure about the rest, but going to do second ecu of the same type to confirm the result.
  14. #134
    Chiba
    Epcos are a pretty good brand, and low ESR in this application is a non-essential nicety. Good to hear another ECU is fixed.
  15. #135
    May 2010
    Moscow
    Think I should say a couple words on the effect of the procedure.
    Initially, when I replaced 4a/t with 5-speed unit (+new ECU, new loom, ETCS-i throttle) I noted low idle upon warm-up. I thought it was some etcs-i feature as the engine continued to start fine. However it got worse as outside temp went lower . To the point I could hardly start it when it was -15C (heavy missing, low rpm). I borrowed a second ECU with the same result. So I thought the problem was the engine itself.
    However, after caps replacement warm-up idle jumped to well above 1000 rpm, and now engine starts quick and nice even in -10C.
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  2. max safe power on 1JZ with std injectors and ecu (with FCD)??
    By RORZ_JZA70 in forum Tech and Conversions
    Last Post: 14-08-2006, 11:59 AM
  3. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 10:31 AM
