your running 1000cc injectors and no after market ECU? No offence ment, but if you are chasing that sort of power, your mad not having an autronic or motec ecu! if your going to all this trouble a few extra grand is well worth it.
Mate, i said buy an ecu because you are making it so you have zero saftey! if you had a small upgrade on injectors etc it would be ok, but still a bandaid solution!
You have gone this far, be patient and save for the ecu or it could cost you twice what the ecu will cost and your back to square one.
Yes there is a solution for what you need if you looked into it, but i for one wouldnt be giving to you because i can see the grief that will come from it.
Bodgy can work at times, but you shouldnt be bodgy with the money you have spent!
