Alright.
1SZ-FE Lifters, in 5.12mm
13751-23030
through
13751-23310 which is 5.68mm.
They make them up to 5.74mm although it isnt listed.
Should be on the Toyota system soon.
I thought It'd be a good idea to get all the part numbers for those little bits and peices all in one place. Becuase I know it makes it a hell of alot easier to order stuff direct from Ttoyota if you have the correct part number, and saves alot of time.
Template: Engine/Series/Part/Number
Example: 4AGE 16v Smallport Water Pump - 1234567890 (note this is jsut an example and not actually the real number.)
I'll start the ball rolling:
4AGE 20v Timing Belt - 13568-19035
4AGE 20v Alternator Belt - 99365-70840
Alright.
13751-23030
through
4A-GE/GZE oil pump: 15100-19036
4A-GE/GZE Complete engine gasket set: 04111-16113
edit: gasket set is for big port, (out of AE92)
Thats all i got so far.....
Originally Posted by The Witzl
Originally Posted by slide86
Might be a good idea to state whether the gasket kit is to suit bigport or smallport. cheers
found some on the old forums firstly courtesy of Garth (ae86drift)
AE86 KOUKI TRUENO
Front Bumper (52119-12092) - $134.18
Front Bumper Bracket Right (52011-12221) - $45.77
Front Bumper Bracket Left (52012-12221) - $45.77
Bumper/Clearance/Turn Signal Right (81510-80038) - $55.45
Bumper/Clearance/Turn Signal Left (81520-80038) - $63.92
Front Grill (53100-12232) - $26.98
Grill Emblem (75314-12021) - $17.00
Rear Bumper (52159-12062) - $176.83
Rear Bumper Bracket Right (52015-12111) - $33.65
Rear Bumper Bracket Left (52016-12111) - $33.65
Redline Tail Light Right (81550-1A291)$181.46 (ToyotaPart)
Redline Tail Light Left (81560-1A291) $181.46
Redline Tail Light Center Piece (75803-12070)
Black Limited Trueno Emblem (75314-12030) - $27.63 (ToyotaPart)
ZENKI TRUENO
Front Bumper (52119-12140) - $95.59
Front Bumper Bracket Right (52011-12230 DISCONTINUED)
Front Bumper Bracket Left (52012-12230 DISCONTINUED)
Zenki Trueno Front Lip (76081-12020) - $586.57
Emblem (75314-19015) - $20.32
Rear Bumper Bracket Right (52015-12110) - $57.36
Rear Bumper Bracket Left (52016-12110) - $57.36
Rear Bumper (52159-12091-08) - $350.78
Rear Bumper Seal (52591-12010) - $5.21
ZENKI LEVIN
Zenki Levin Bumper (52119-12090) - $130.18
Zenki Levin Front Left Bumper Bracket (52011-12220) - $44.99
Zenki Levin Front Right Bumper Bracket (52012-12220) - $44.99
Levin hood (53301-12442) - $232.18
Grill (53100-12220) - $90.80
Zenki Levin Right Fender (53801-1A860) - $160.18
Zenki Levin Left fender (53802-1A560) - $160.18
Zenki Levin Front Lip (76081-12010) - $386.53 76081-12010
KOUKI LEVIN
Kouki Levin Right Fender (53801-1A770) - $167.69
Kouki Levin Left Fender (53802-1A760 or 1A661?) - $167.69
Kouki Levin Bumper (52119-12142) - $139.50
Kouki Levin Front Right Bumper Bracket (52011-12231) - $34.98
Kouki Levin Front Left Bumper Bracket (52012-12231) - $34.98
Bumper Support (52115-12240) $8.49 each
Bumper Turn Signal(left) (81520-80024) - $43.34
Corner Light(left) (81620-12290) - $55.30
Corner Light(right) (81610-12290)
Door Molding (75732-12251-08)
Headlight(left) (81150-1A021) - $204.30
Headlight(right) (81110-1A261 ) - $204.30
SHARED PARTS
APEX Twin Cam 16 Decal (75443-12550-03) - $10.46
GTV Decals (75985-12380) - $20.53
Smoked Turn Signals (81731-12173DISC. - 81741-12163DISC.) - $11.08 each
Sprinter Trueno Decal Coupe (75441-12320-03) - $21.86
Sprinter Trueno Decal Hatchback (75441-12321-03)
TRUENO Decal(Black) (75442-12790-03)
Trueno Mudflaps (76608-19265 / 76607-19265) $52.79 each
OEM Sideskirts (76901-12010DISCONTINUED / 76902-12010 DISCONTINUED)
1985 FR Corolla Repair/Metiance Maunal - (36241A)
1986 FR Corolla Repair/Metiance Maunal - (RM003U)
1987 FR Corolla Repair/Metiance Maunal - (RM040U)
Stock Toyota "Snowflake" Wheels (86/87 mdl.Year) - (4261112790)
TRD JAPAN
Rear Hatch (67005-AE801-60)
Rear Hatch Wing (64440-AE801)
Carbon Fiber Hood (53311-AE820)
TRD JAPAN AE86 Lowering Springs
TRD NW Pricing
(NW4AGE/HachiRoku.net discount)
NOTE: Each part # represents ONE spring, not a pair or set!!!
Fronts: $58 each
Rears: $41 each
Front Springs2.0kg/mm(rally) (48131-AE851)
Front 2.4kg/mm(rally) (48131-AE861)
Front 6.0kg/mm(race) (48131-AE801-60)
Front 8.0kg/mm(race) (48131-AE801-80)
Rear 2.3 kg/mm(rally) (48231-AE861)
Rear 3.9 kg/mm(race) (48231-AE801-39)
Rear 4.3 kg/mm(race) (48231-AE801-43)
Rear 4.7 kg/mm(race) (48231-AE801-47)
Rear 5.1 kg/mm(race) (48231-AE801-51)
Rear 5.5 kg/mm(race) (48231-AE801-55)
Rear 6.0 kg/mm(race) (48231-AE801-60)
Rear 6.5kg/mm(race) (48231-AE801-65)
Rear 7.0kg/mm(race) (48231-AE801-70)
Rear 8.0kg/mm(race) (48231-AE801-80)
Rear 9.0kg/mm(race) (48231-AE801-90)
TRD USA
ShortShift Kit (00602-30301-002) - $199.74
Front Sway Bar (00602-48810-001)
Lowering Springs (00602-48130-001)
Oil Filler Cap-Kanji screw-on (00602-12108-001)
Oil Filler Cap-Japan screw-on (00602-12108-002)
Radiator Cap 18.5 psi (00642-16401-001)
Radiator Cap 21.3 psi (00642-16401-002)
Plug Wires(race) (00642-90919-000)
Headers new revision(race) (00642-17141-012)
Valve Springs(race) (00643-90501-000)
Cam Gear 4AG (adjustable) (00642-13523-001)
Fuel Pressure Riser(adjustable) (00643-23280-000)
Metal Head Gasket (00643-11115-000)
Clutch Kit(street) (00642-31200-020)
Clutch Kit(race) (00643-31200-021)
Oil Filter(race) (00642-90915-002)
Front Shocks(pair) (00602-48511-031)
TRD 11,000RPM tach (83270-14080)
TRD water temp gauge (83410-14070)
TRD oil temp gauge (83560-14010)
TRD oil pressure gauge (83510-14010)
TRD center lock kit (40206-AEA01)
Camshafts
Intake 304 (13501-AE851)
Intake 288 (13501-AE861)
Intake 272 (13501-AE871)
Exaust 304 (13502-AE851)
Exaust 288 (13502-AE861
Exaust 272 (13502-AE871
headlight "eyelash" right - 54107-012010
headlight "eyelash" left - 54108-012010
side indicator left - 12-246L
side indicator right - 12-246R
Can anyone find out if these are correct?
for a Kouki Levin.. headlight eyelids.
top left: 5323412050
top right: 5313312040
bottom both sides: 5313212260
1986 JDM AE86 GT Apex panda coupe
1997 JDM AE111 Trueno
1983 AE86 hatch GZE
1984 AE71 5sp
1998 JZX100 TRD
I just rang Blacktown Toyota for this..
KOUKI LEVIN Corner Light(left) (81620-12290)
it didn't register in the computer.
Neither did this...
too many digits or something
1983 AE86 hatch GZE
1984 AE71 5sp
1998 JZX100 TRD
WHAT...
no way are they that cheap! checking right now!
AE86 - coming soon to a quiet mountain pass near you...
WRX - currently epa'd...
3S-GTE ST205
(ST205) rebuild gasket kit 04111-74540
(ST205) oil pump 15100-88460
(ST205) water pump 16100-79235
(ST205) TRD head gasket 11115-SW210
(ST205) cambelt 13568-79105
(ST205) tensioner 13540-88480
(ST205) tensioner pulley 13505-88480
(ST205) idler pulley 13503-63011
(ST205) g/box gasket set 04331-20061
18R-GEU
chain guide, upper chain int. side (tenstion no.2), 13559-88270
Chain guide, lower chain, Ex. Side, 13561-34010
Chain guide, upper chain, uppermost, 13562-88280
Chain Guide, upper chain ex. Side, 13563-88250
Chain Tensioner No.2, 13550-88270
Chain Tensioner No.1, 13540-33014
4A-GE/4A-GZE Smallport
4A-GE 100kW full gasket kit, 04111-16191
8.9:1 4A-GZE piston, 0.5mm OS, 13103-16131
Piston ring, set 4, suit 13103-16131, 13013-16210
just a not on those part numbers for the sprinter. they are not toyota australia part numbers. just called toyota then and he said there was no listing for about 6 of the random ones i picked.
1JZGTE Timing Belt 90-92 - 13568-49025
1JZGTE Timing Belt 92-93 - 13568-49065
1JZGTE Camshaft seal 90-93 - 90311-38041
1JZGTE Serpentine Belt (hydro waterpump) - 90916-02305
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Originally Posted by 45aken
tell me which ones they are and ill remove them. i jsut copied and pasted the info over from the old forums a post that garth put up in a thread (ae86drift)
also take into consideration that these may very well be Japanese part numbers, especailly considering that they are for trueno and levin and NOT sprinter.
It won't matter if they're Jap spec or not. I've ordered an ae86 4age waterpump which is obviously jdm and the part numbering system is identical. Those eyelid parts have the wrong part no.s though... It should beOriginally Posted by Dom-KE55
RHS: 81117-1A261
LHS: 81157-1A021
This is the correct part number... try a different Toyota. They might just be lazy punks and not want to order the part in.I just rang Blacktown Toyota for this..
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
yo eddie tell me which actually numbers need changing and will do so i cant work out which ones u mean from what youve written, cheers
All for UZZ30 From : 09/1997 To : 07/2000
Description STRAINER SUB-ASSY, OIL
Callout: 15104
Part : 1510450130
Description : GASKET, OIL STRAINER
Callout : 15147
Part : 1514750011
Description : STANDARD PART NUT
Callout : 9017906307
Part : 9017906307
Description : STANDARD PART BOLT
Callout : 9162160612
Part : 9162160612
../delete/ban
tech moderator
