hmm
I really want to find out how I can get the kouki eyelids for the levin headlight.
I also need the fog light bracket that attached to the headlight
These ones:
top left: 5323412050
top right: 5313312040
should be changed to these:
LHS: 81157-1A021
RHS: 81117-1A261
EDIT: I just realised those 1st part numbers are TRD usa ones. The part nos i've given might not be for the same part. The EPC describes them as "rim for headlamp" but they are definately Kouki parts.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
hmm
1986 JDM AE86 GT Apex panda coupe
1997 JDM AE111 Trueno
1983 AE86 hatch GZE
1984 AE71 5sp
1998 JZX100 TRD
toyota cressida 1988-1993. engine 7MGE
Air Filter Element 17801-70020
Spark plug (Denso unit) PQ16R
I will try to add other parts later.
1G-GTE
Timing Belt: 1356879035
Oil Pump Seal: 9002921020
Cam shaft Seals: 9031135040
Just bought these from Toyota, so I know they are correct. Other timing belt numbers have come up, but do not work!
Dylo
This guide is for information purposes only.It is a replacement parts guide for 93.5-98 Supra TT / NA models.
FILTERS:
air filter-#17801-07020
fuel filter-#23300-49195
oil filter-#90915-20004 [jap made]
pcv valve-#12204-46020[TT]
pcv valve-#12204-46030 [NA]
pcv grommet-#90480-18001
FLUIDS:
automatic-#08886-81015 type-t-iv
getrag 6spd-#08885-01306 v160
antifreeze-#00272-1LLAC-01 Toyota Red
engine oil- 5w30 or 10w30
differental oil- 75w-90 or equilivent
disk brake grease-#08887-80609
WIPER PARTS:
blade assy rh-#85212-33011
blade assy lh-#85222-14610 [also works on rh side]
blade assy rear-#85242-14020
refill frt rh-#85214-YZZB7
refill frt lh-#85214-YZZB9
refill rear-#85214-YZZB6
arm rh-#85211-14310
arm lh-#85221-14310
arm rear-#85241-14020
TUNE UP PARTS:
plugs-#90919-01178 [TT] ND platinum
plugs-#90919-01210 [TT] ND iridium
plugs-#90919-01168 [NA] ND platinum
plugs ngk for bpu-#3330
dist cap-#19101-70020 [NA]
dist rotor-#19102-46011 [NA]
wires-#90919-21521 [NA]
coil-#90919-02205 [TT]
coil-#90919-02207 [NA 93.5-97]
coil-#90919-02216 [NA 98]
coil elec. plug repair-#90980-11246
BELTS:
drive belt-#90916-02310[serpentine]
drive belt tensioner-#16620-46070 [TT 6spd]
drive belt tensioner-#16620-0W025 [NA all /TT auto]
timing belt-#13568-49036
BRAKES:
frt pads-#04465-14150 [TT for 4pot calipers]
frt shims-#04945-14110[TT]
frt clips-#04947-14010 [TT]
frt pad pins-#90240-06019[TT]
rear pads-#04466-14040 [TT]
rear shims-#04946-14030 [TT]
rear clips-#04948-14010 [TT]
rear pad pins-#90240-06017 [TT]
frt rotor rh-#43512-14200 [TT]
frt rotor lh-#43516-14030 [TT]
rear rotors-#42431-14150 [TT]
cal kit frt-#04479-14140 [TT]
cal kit rear-#04479-14130 [TT]
cal assy frt rh-#47730-14260 [TT]
cal assy frt lh-#47750-14270 [TT]
cal assy rear rh-#47730-14270 [TT]
cal assy rear lh-#47750-14280 [TT]
frt pads-#04465-14081 [NA and 2pot caliper TT]
frt shims-#04945-14010 [NA]
frt clips-#04947-24030 [NA]
frt cal pins-#47715-24010 [NA]
rear pads-#04466-30030 [NA]
rear shims-#04946-24010 [NA]
rear clips-#04948-50010 [NA]
rear cal pins main-#47715-06030 [NA]
rear cal pins sub-#47715-06020 [NA]
frt rotors-#43512-14190 [NA]
rear rotors-#42431-30140 [NA 93.5-95]
rear rotors-#42431-30240 [NA 96-98]
cal kit frt-#04479-14120 [NA]
cal kit rear-#04479-24030 [NA]
cal assy frt rh-#47730-24082 [NA 93.5-94]
cal assy frt lh-#47750-24082 [NA 93.5-94]
cal assy frt rh-#47730-14281-84 [NA 95-98]
cal assy frt lh-#47750-14291-84 [NA 95-98]
cal assy rear rh-#47730-14240-84 [NA]
cal assy rear lh-#47750-14240-84 [NA]
WHEEL BEARINGS/SEALS
frt axle hub-#43502-30140
frt wheel brg-#90903-63006-77
frt wheel seal-#90311-50008
rear axle hub-#42301-30030
rear wheel brg-#90369-43005-77
rear seal inner-#90311-63001
rear seal outer-#90311-57001
CLUTCH PARTS:
pilot brg-#90363-12002-77 [TT-NA]
t/o brg-#90903-63001 [TT]
t/o brg-#31230-22100 [NA]
clutch cover-#31210-14170-84 [TT]
clutch cover-#31210-30261-84 [NA]
clutch disc-#31250-14190 [TT]
clutch disc-#31250-30391-84 [NA]
clutch master-#31410-14310
clutch slave-#31470-22120 [NA]
clutch slave-#31470-14060 [TT]
clutch master kit-#04311-12110
clutch slave kit-#04313-14020 [TT]
clutch slave kit-#04313-17010 [NA 93.5-96.5]
clutch slave kit-#04313-22030 [NA 96.6-98]
clutch fork-#31204-14060 [TT 6spd]
clutch fork-#31204-22050 [NA 5spd]
ENGINE PARTS:
02 sensor-#89465-19605
cam seals-#90311-40020
crank seal-#90311-46001
rear main seal-#90311-90006
v/c gskt intake-#11213-46020
v/c gskt exhaust-#11214-46011
v/c gskt exhaust-#11214-46030 [NA 98]
silicone gasket sealer-#00295-00102 [the black stuff in a tube]
pcv hose frt v/c-#12264-46010 [TT]
pcv hose rear v/c-#12263-46010 [TT]
fuel pump-#23221-46070 [NA 93.5-97]
fuel pump-#23221-50060 [NA 98]
fuel pump-#23221-46110 [TT]
fuel pump brkt-#23206-46160 [TT]
fuel pump brkt-#23206-46140 [NA]
t-belt ilder-#13505-46041
t-belt tensioner-#13540-46030
t/stat-#90916-03093
t/stat gskt#16325-62010
w/pump-#16100-49837 [NA]
w/pump-#16100-49846 [TT]
rad cap-#16401-62100
alternator-#27060-46200-84 [TT 6spd]
alternator-#27060-46120-84 [TT auto]
alternator-#27060-46190-84 [NA 93.5-95.5]
alternator-#27060-46050-84 [NA 95.6-98]
starter-#28100-46140-84
engine mounts-#12360-46070[93.5-95.4]
engine mounts-#12360-46111[95.5-98 improved design]
trans mount-#12371-46110 [TT 6spd]
trans mount-#12371-46120 [TT auto]
trans mount-# 12371-46090[NA 5spd]
trans mount-#12371-46020 [NA auto]
radiator assy-#16400-46420 [TT 6spd Alumin.type]
radiator assy-#16400-46430 [TT auto alumin.type]
radiator assy-#16400-46290 [NA 5spd]
radiator assy-#16400-46300 [NA auto]
short block assy-#11400-49088 [TT]
full gskt kit engine-#04111-46094 [TT]
BODY PARTS:
hatch stay rh-#68950-19895 [w/spoiler]
hatch stay lh-#68960-19585 [w/spoiler]
hatch rubber stopper-#67293-14051[stops the squeak]
screws for above 2ea-#90159-50116
targa roof-#63201-14060
targa mld rh-#63217-14030-C0
targa mld lh-#63218-14020-C0
targa w/strip rh-#62383-14030
targa w/strip lh-#62384-14030
targa headliner-#63312-14050-C0
targa bolts frt-#90901-09004
targa bolt /brkt rear rh#63240-14090[2pc brkt w/bolt]
targa bolt/ brkt rear lh#63240-14060 [2pc brkt w/bolt]
targa ctr.lock assy-#63203-14100
HELICOIL KIT FOR TARGA BOLTS-#5546.6 [6mm x 1.0]
turbo spoiler rear-#76085-14909
frt glass mld-#75533-14190
back glass mld-#75573-14210
floor carpet-#58510-1B171-A0 [ stick/ivory]
floor carpet-#58510-1B171-C0 [stick/black]
floor carpet-#58510-1B181-A0 [auto/ivory]
floor carpet-#58510-1B181-C0 [auto/black]
rear lisc.plate nuts-#52121-24020
tonneau cover trunk-#64910-14060-C0
power antenna-#86300-14411
power antenna mast only-#86337-14411[chrome only]
ash tray-#74102-14130 [93.5-96]
ash tray-#74102-14140 [97-98]
ACCESSORIES:
front end mask-#00218-14930
mudguards frt-#76095-14010
wheel locks-#00276-14930
floor mats blk/ivory logo-#00200-14930-08
floor mats blk/silver logo-#00200-14930-13
floor mats blk/SE logo-#00200-14950-01 [discontinued]
EMBLEMS:
gold NA kit -#00211-14950[no "turbo"logo]{discontinued}
gold TT kit -#00211-14970 [w/"turbo" logo]{discontinued}
gold SE kit-#00211-14954 {discontinued}
gold SE logo only-#00211-14953 {discontinued}
gold ctr cap logo-#00211-00951
gold ant. nut-#00577-35950
gold "logo"frt-#00211-14956
gold "toyota"-#00211-14951
gold "supra"-#00211-14952
gold "logo"rear-#00211-14957
15th anniv.logos-#00211-14971-01 blk
15th anniv.logos-#00211-14971-28 silver
SE side stripes rh-#00211-4R951
SE side stripes lh-#00211-4L951
"turbo"logo -#00016-23940{small brushed Aluminium w/black letters used by Toyota Southeast Distributors.94-95?TT}
frt cover "logo" grey-#75314-14010
tailgate "toyota"grey-#75441-14190
tailgate "logo" grey-#75471-14010
tailgate "supra" grey-#75442-14280[93.5-96 TT all NA]
tailgate "supra turbo" grey-#75443-14180[97-98 TT]
trd 3pack logo-#00602-42601-EMB[carbon fiber style 1"x2.75" "toyota racing development"red letters "TRD" chrome large letters]
TRD SPORT PARTS:
trd sway bar kit f&r-# 00602-48800-003
trd strut tower brace-#00602-53607-007
trd spring/strut kit-#00602-48000-008 [NA][discontinued]
trd spring/strut kit-#00602-48000-009 [TT] [discontinued]
trd SS brake lines-#00602-47300-012[discontinued]
trd oil filter-#00642-90915-001
trd oil cap-#00602-12108-003
trd air filter-#00642-17801-002[oem style]
trd rad cap-#00642-16401-003
trd clutch kit-#00602-31201-010 [TT]
trd gen 2 exhaust cat back-#00602-17400-016 [TT]
trd fuel pressure regulator-#00643-23280-000
trd brake pads-#00602,00643-XXXXX-XX [all discontinued]
trd 10,000 rpm tach-#[all discontinued]
DRIVETRAIN:
getrag 6spd assy-#33030-0W212
silicone trans pan sealer-#00295-01281 [orange stuff]
atm screen filter-#35330-30011 [NA 93.5-97]
atm screen filter-#35330-50010 [TT /NA 98]
drive shaft-#37100-14810 [TT 6spd]
drive shaft-#37100-14820 [TT auto]
rear diff pinion seal-#90311-50018 [6spd]
rear diff pinion seal-#90311-44005[ TT auto-NA all]
rear diff axle seals-#90311-45013 [6spd]
rear diff axle seals-#90311-47008 [auto all/NA 5spd]
input shaft seal-#90080-31037[TT 6spd]
output shaft seal-#90080-31029[TT 6spd]
shift rod case seal-#90080-31032[TT 6spd]
OIL PRESSURE SENSOR MOD:
union bolt-#90401-19008
gasket-#90430-20016
o ring-#90301-68005
EXTERIOR LIGHTING:
3rd stop lamp-#81570-14060[93.5-94]
3rd stop lamp-#81570-14061[95-98]
head lamp lh-#81151-1B241 [98 style grey no bulbs]
head lamp rh-#81111-1B241 [98 style grey no bulbs]
tail lamp lh-#81561-14700 [98 style grey no bulbs]
tail lamp rh-#81551-14700 [98 style grey no bulbs]
t/s lamp frt rh-#81510-80086 [97-98 clear assy w/bulbs]
t/s lamp frt lh-#81520-80086 [97-98 clear assy w/bulbs]
t/s frt harness -#81515-14390[97-98 pig tail for aftermarket lamps]
turn signal/hazzard flasher-#81980-12070
indicator-#81730-20220 [93.5-96 style indicators in clear]part is actually for the 2003 corolla but perfect fit for supra
EXHAUST HARDWARE:
lock nuts-#90179-08059 [8mm w/washer for 02 studs/ misc]
lock nuts-#90179-10070 [10mm w/washer for studs / misc]
bolts-#90105-10023 [ 10mm w/washer for exh pipes]
nuts-#94180-41000 [10mm w/washer for exh pipes]
studs-#90179-10070 [10mm for most mainfolds/exhaust]
INSTRUMENT PANEL BEZELS 97/98
part# 55410-14530 ctr upper
part# 55404-14570 lh dash
part# 55420-14060 speedo bezel
part# 55405-14170 radio/hvac panel
part# 58804-14100 6spd shift bezel
part# 58804-14110 atm shift bezel
part#74232-14121 lh door switch bezel
it would help if those posting part numbers would note which fit the Australian delivered cars and which are unique to imports only (eg AE86 trueno parts that are unique to trueno or Levin versus those that fit local Sprinters). If Toyota Australia have not sold the part in 24 months (I believe) , it wont come up on their system, but they can request an ex Japan price if they think you are serious. Apart from a few unique Australian made decals, accesores etc, the Jap & Australian part numbers are shared. I have a Toyota parts account and dont have a problem, but I generally find it cheaper to get small JDM parts direct from overseas. Thanks
I think its a bit more than 24 months, but the system does get purged occasionally.
Terry makes a good point.
i did post this seperately, but might aswell post it here aswell.
its part numbers for most things on the silver 20v 4age. (its a .xls file, so right click ,save as)
just bumping it up so it doesnt get lost in the mayhem!
http://www.rollamods.com/main.htm
Click on Tech and then choose either AE101 or AE111 part numbers for a list.
c/o Mr Purcell
If any Toyota dealer gives you grief and tells you that a part does not exist or is discontinued try Toyota in Castle Hill.
Both Penrith and Windsor Toyota have told me certain parts of my car are no longer available and then the same week I ask Toyota Castle Hill and they just say they've got to order in from Japan.
I think a lot of Toyota dealers just couldn't be bothered reviving part numbers in their system so they don't bother looking at the other more complete (Telnet to Japan I think) system.
Sorry for the drag-up but it's relevant. Looking at the GZE piston part numbers above, does anyone know what the -01 -02 -03 suffix means?
See here: http://www.toyodiy.com/parts/p_J_199...CMXR_1301.html (if doesn't work, click "engine/fuel" and then "crankshaft/piston" to bring it up again)
