Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 118
Thread: How To ... Tacho Booster
  1. #61
    Sep 2011
    Default Re: How To ... Tacho Booster
    just bumping this thread,
    put a tacho into my crown (pins were +VE, 1, -VE).. connecting signal from Alternator and coil, onto +VE and -VE pins (didnt use 1, as i didnt know what it was for).
    the tacho worked a treat, had correct idle etc, revved freely etc etc .... then 2 days later after starting car and on the first rev it cut out and died.
    is this a case of needing a tacho booster? ... or did i fry something in the tacho (VH commo 6cyl tacho)
    1974 Crown SE -- the "kandy" crown
    1971 Ford Capri GT -- 624rwhp at 25psi ... 1000kg race weight ... 4L with T51
    For Sale: 6x 1000cc Rochester 2JZ top feed injectors ($600 ono) & JIC dampening adjustable coilovers JZA70 $800
  2. #62
    Dec 2008
    Wellington, NZ
    If this stupid feckin ap had a delete function I would have deleted this post, but since it doesn't, I'll put this angy shit in here to remind people to read the whole feckin post before making a response
  3. #63
    Jul 2011
    victoria
    i built a external one recently and it worked a treat! quite simple really also it shouldn't click cause all your using out of the relay is the coil so u can use a smaller relay, pcb relay (more compact i guess) from jaycar and just use each of the pins from each side of the coil
  4. #64
    Jan 2012
    Hey guys, I joined this forum to ask about this despite not having a toyota (although I'm enjoying the cars for sale section immensely ) and need a little help. I wired up all this stuff for my nissan S12 gazelle that runs an SR20DE+T off a microtech but it doesn't work. I tested the voltage of the signal wire and it was around 3 volts I think (I can't remember exactly) and then once I used the pull up resistor it changed it to 12v. However the tacho still doesn't work.
    Previously I had tried running a wire to diode off each of the wires coming out of the ignitor then joining the wires to one after the diodes, however upon closer inspection the microtech does not seem to use the stock ignitor at all so this was a waste of time. Could I run this setup with the wires coming off the coilpack signal wires or earth wires then through a diode or could this send too much voltage to the tacho? Any help would be great. I'm very new to auto electrics but keen to learn. Thanks.
  5. #65
    Put a Autometer Tacho in a Datto 1200 running an early AE92 4AGZE. It happily ran from the 5V IGN signal directly from the ECU.
  6. #66
    Nov 2011
    hey blacky
    this relay setup works on mostly toyotas
    on nissans I use a different type of booster
    I get from china
    these work when u wire a late rb into a dr30
    skyline so I presume your tacho would work
    a similar way
  7. #67
    Jan 2012
    Yeah I was trying to steer clear of an aftermarket tacho if I could avoid it broken22. Do you have a link to the chinese booster you used in the DR30 dumbass? Cheers.
  8. #68
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Just made one of these thanks heaps guys
  9. #69
    Jan 2012
    If anyone in Brisbane needs one of these free I have one spare as it didn't work on my car (the signal was 12v but the tacho didn't respond).
    I have no idea how to get my stock S12 tacho working so I will be investigating changing the mechanism for an S13 one if I can fit it ok, or possibly just use an aftermarket one.
  10. #70
    Nov 2011
    u need a Nissan booster
    pm me as I sell em
  11. #71
    Jan 2012
    Yeah, that's the plan once I get the cash and the other things I need to fix sorted. I don't have a booster anymore, I hope it worked .
  12. #72
    Dec 2009
    Kwazulu Natal
    Hey guys.
    I've made a few of these that work on all the cars I've done so far.
    But I have a friend with a Nissan Exa Turbo e15et engine.
    We have fitted msd to it, but now the rpm doesn't work.
    I fitted one of these to his car but still doesn't work.
    I have tested the tach booster on another car and it does work.
    On the original coil negative his car pulses 12 - 13v to the cluster rpm guage and it works.
    With the tach booster I get about 9v going to the cluster rpm guage.
    It seems that it is too low for the cluster to work.
    How would I go about increasing the 9v to around 12v ?
  13. #73
    Nov 2011
    i have afew different types of tacho boosters
    one mainly does toyotas
    the other mainly does nissans
    so this relay trick doesnt work on most nissans
  14. #74
    May 2007
    is this what i will need to make the factory GA70 tacho work from the signal from my microtech?
    is the factory dash from the 1ggte
    ive tried to make one before but failed so dumbass if you have one i can buy i might be interested
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
  15. #75
    Yes you need the $10 tacho booster i posted for your application
    ...... butt scratcher?!
  1. Tacho tech
    Last Post: 04-08-2009, 05:10 PM
  2. Tacho Booster !
    By itchybum1 in forum Tech and Conversions
    Last Post: 28-03-2008, 10:36 PM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 10:36 AM
