Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 118
Thread: How To ... Tacho Booster
  1. #76
    May 2007
    Default Re: How To ... Tacho Booster
    is the one you posted the same when doing a jza80 NA to a 1jzgte using the microtech output to use the factory tacho?
    as thats the combination i failed at... maybe i need to do another attempt at it...
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
  2. #77
    hmmm... not sure about the JZA80 factory tacho...... this mod is generally for older toyota factory tachos.
  3. #78
    May 2007
    ok well ill give it a go and hopefully it will work this time around
  4. #79
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    External booster images are down?
  5. #80
    errr.... no they arent.
    http://www.toymods.org.au/forums/sho...=1#post1017046
    Unless you have a block on photobucket?
  6. #81
    Aug 2008
    They were not showing yesterday.
  7. #82
    May 2007
    so finally got around to doing this...
    failed on my ga70 tacho... not sure if the tacho itself might have been fked from previous things but has been left disconnected for many years and worked prior to this...
    luckily i had a spare ma70 auto dash sitting in the shed and pluged it in... worked fine... so figured ide swap that tacho into the ga70 dash as the rest of it is modified...
    well first it didnt work so then had to swap the circuit board for the tacho over then it all worked...
    downside though is the relay audibly clicks... will have to de click it another day...
  8. #83
    Jul 2009
    Built one of these for my AW11 to get the tacho to work with my DIYPNP MegaSquirt. Works like a dream and the relay doesn't click
  9. #84
    May 2007
    Out of interest what relay did you use?
    i used the one listed but wondering if a narva relay would have more success...
  10. #85
    Jul 2009
    I'd have to go have a look, but it was a relay from a box of 10 I bought from ebay about 10 years ago... Definetely something shipped out of china.
  11. #86
    May 2007
    ah ok well dont stress too much... ill fix it one way or another
  12. #87
    I only ever find my one to click on really low rpm, like cranking.
    All relays come from China anyway.... Narva just add a hefty premium because they are narva
  13. #88
    Jan 2012
    Quote Originally Posted by debeerd View Post
    Hey guys.
    I've made a few of these that work on all the cars I've done so far.
    But I have a friend with a Nissan Exa Turbo e15et engine.
    We have fitted msd to it, but now the rpm doesn't work.
    I fitted one of these to his car but still doesn't work.
    I have tested the tach booster on another car and it does work.
    On the original coil negative his car pulses 12 - 13v to the cluster rpm guage and it works.
    With the tach booster I get about 9v going to the cluster rpm guage.
    It seems that it is too low for the cluster to work.
    How would I go about increasing the 9v to around 12v ?
    How did you go with this? If you are still struggling I suggest you give this a try. I finally stopped being a retard and wired the diodes off the POST ignitor wires and now my tacho works on my S12
  14. #89
    May 2007
    Quote Originally Posted by The Witzl View Post
    yeah i dunno but definitely audibly clicks...
    seems to get un noticeable at cruising under light load but upon backing off becomes louder...
    ill remove the bit that clicks and be done with it
  15. #90
    yep that'll do the trick
    All told, this is still a dirt cheap solution!
  1. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 04:10 PM
  2. Tacho Booster !
    By itchybum1 in forum Tech and Conversions
    Last Post: 28-03-2008, 09:36 PM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
