Results 1 to 5 of 5
Thread: Where do these lines go
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Where do these lines go
    howdy just gathering the info i need to put my turbo kit on and there a air line from the wastegate and one from the turbo. I got no experience with these so don't know where they go.
    Also is this hole for a temp gauge sensor?
    thanks
    Previous Rides: JZA80, GA70 GT, RA63 GT x2, TA61 GT, TA63.
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default Re: Where do these lines go
    Run a hose from the points you have indicated from the turbo to the wastegate (or boost control solanoid), to control boost, there may be boost response benefits to hooking the wastegate line up to the intake plenum and blocking the fitting on the turbo...
    Oh, that hole at the bottom of the manifold is possibly for exhaust temp sensor or thermocouple. Is it threaded? You would want to block it with something at least!
    the hole on the manifold will be for the 1ggggggte o2 sensor,
    victoria
    nah, thats sitting in the dump pipe in the bottom photo. probally for a temp sensor
  1. DIY fuel and brake lines
    By Norbie in forum Tech and Conversions
    Last Post: 08-04-2007, 08:53 PM
  2. Garrett Turbo coolant lines
    By NAJJE in forum Tech and Conversions
    Last Post: 27-03-2007, 08:15 PM
  3. 22RE/RT142 (a) "Engine" light and (b) vac lines
    By Shifty in forum Tech and Conversions
    Last Post: 07-01-2007, 07:56 PM
  4. LPG Explained... An Intro to LPG
    Last Post: 19-09-2006, 09:20 AM
