Results 31 to 45 of 53
Thread: Toyota (duh) RWD Gearbox comparisons
    The Supreme Backyard Mechanic
    Default Re: Toyota (duh) RWD Gearbox comparisons
    if you still want pics, i have sitting in my shed and another at a mate's place.
    EDIT: of the J160 3sge box that is.
    from crUZsida, W58 shifter positions (futherst forward one is still 1" back from T50?
    sorry in advance for bumping an old thread but it is a useful one
    oldcorollas do you mean w5# front position is 1" back from early (direct selector) or late (remote selector) t50? and how reliable is this info?relevant for a conversion i am working on.
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    Nov 2007
    I found that w5* front position (ra60) is 30mm shorter from front of bell to gear stick when compared to ae86/71 t50.
    Here's a pic of W58 with forwardmost shifter housing in an ae71 with 4age.
    Hope that helps you Micheal.
    That pic is not my car. Mine is ae86 but experimentation showed the exact same result. So, after discovering that it was going to look/locate like that I decided to/have used the rearmost (sa63) shifter housing which sits right up against the back of the shifter hole in the tunnel.
    Because I'm also running a quick-shift stick (as in pic) and thus losing the rear biased dogleg in the stock stick, I wanted the housing as far back as possible.
    Anglo maxum Grease Monkey
    Jun 2006
    If you are talking about the above.
    Left = MA61, RA60, RA65
    Left + 1 = LX80 or LY80, we couldn't read the writing.
    Right - 1 = MA70, GA70
    Right = SA63
    i tend to disagree, i have an sa63 and its more simmilar to right-1 than right.
    ke70, drift/hillclimb/sprint special
    bells AND whistles.
    vic
    No SA 63 has the rearmost one 100%
    Dave
    Quote Originally Posted by driftke70
    You are wrong
    SA63 is rearmost.
    Perhaps the box is not the original ?
  8. #38
    New Zealand
    Ok so incase anyone wanted to know a W50 from a crown etc (m-series) is <edit> FRACTIONALL shorter than a w57. I measure a w50 at 705mm from b/h to output back face (not end out output shaft) and my w57 at 690 , can any one confirm this? <edit>
    I have headaches with driveshafts when trying to convert MY mx83 to manual. It kinda works with abit of material removal from the driveshaft, and forcing the shaft into the the w50 but then it leaks like a sieve...doh...
  9. #39
    The first W50 I had was sold to me as a Crown box (had an M bellhousing on it) and was the exact same length as my W58
    I also had a W40 which was the exact same length.
  10. #40
    New Zealand
    doubt caused me to measure. i get about a 15mm diff between the w57 and the w50 i have.
  11. #41
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    A J160 Gearbox has an external shifter, that you can easily move between two positions (2 inches difference) really easily, without the need to purchase or fabricate any extra parts. Unbolt a few bolts and knock out a pin, flip a part around and then remount to a second set of mounting holes and you're done. The Altezza uses the rear position for the shifter.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
  12. #42
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    sorry to dig up an old thread, but rather than start a new one...
    So to convert my 4age to a w55 or w57 i would need a dellow bellhousing? or is there a toyota bellhousing that i can use?
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
  13. #43
    New Zealand
    Dellows are not really rated that highly. You need a Niteparts or one of the Malaysian bellhousings. There is a big thread on the different options around here somewhere.
    Callum
    EDIT - Look here -
    http://www.toymods.net/forums/showthread.php?t=7542
  14. #44
    Resident Mitsu-whore Backyard Mechanic
    Oct 2008
    If anyone wants I can take some photo's of the Mitsubishi 5 speed (Scorpion 'box, NOT BW poo) that I had behind the 3TG in my ST141 before I found a W50. It took a hell of a lot of abuse, and seemed to handle the 110rwhp I've got no worries. My cousin uses one in his rally car (GH Sigma, 2.6 Astron 260hp 400nm) and it has lived quite happily there for the past 9 years, only needing one rebuild.
    Josh
    -Josh
    A165H- In the works.
  15. #45
    So does anyone have any comments to make about the strengths of the W55 vs W58?
    The application is a turbo 18RG.... and it will get some abuse - currently have a W55 put aside for the job.
    Should i just stump up for a W58 when one pops up?
  1. Toyota R Engine History
  2. Toyota Crown MS53 Crown Custom Wagon
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-06-2011, 11:44 AM
  3. Toyota Crown MS63 Custom Wagon Info
    Last Post: 28-09-2007, 12:31 PM
