Results 1 to 2 of 2
Thread: map sensor feed pipe need help
    sir Grease Monkey
    tasmania
    Default map sensor feed pipe need help
    a question for you 1jz guru,s.does the map sensor have to feed directly off the plenum caus i just checked mine and it is hooked up to a line that runs forward through a one way valve into the bottom of the throtlebody. i suspect this could be my problem. can you help . cheers bigwad
    Default Re: map sensor feed pipe need help
    MAP sensors should always be on a dedicated connection to the plenum (ie not sharing it with anything else) and there definitely shouldn't be any valves in there! Ideally the vacuum line should be as short as possible as well.
  1. 1JZGTE ISCV & MAP Sensor Questions...
    By JZA70 R in forum Tech and Conversions
    Last Post: 11-11-2007, 04:52 PM
  2. delete me
    By EldarO in forum Tech and Conversions
    Last Post: 14-04-2007, 09:53 PM
  3. MAP computer on AFM engine with e-manage?
    By timgte in forum Tech and Conversions
    Last Post: 04-10-2006, 08:58 AM
  4. 4AGE AFM or MAP
    By RO11LR in forum Tech and Conversions
    Last Post: 19-09-2006, 06:03 PM
