Results 1 to 13 of 13
Thread: Differences in 1S 2S and 3S engines.
    West Australia
    Default Differences in 1S 2S and 3S engines.
    Hi all.
    Dont post in tech section much ...but i got a question..
    Recently ive heard of this car that sounds good
    it has a 1S-U engine , which i believe only existed in the 1984 -> 1987 Cresta (SX??)
    Ive been searching for information on it and compatible engines released here in Aust.
    can anyone find information on this engine and whether or not anything at all on the engine (water pump etc) is compatible with 2S or 3S engines....
    as i want to keep the 1S-U in the car as its going to be my daily driver.
    coFF.
    Default Re: Differences in 1S 2S and 3S engines.
    I've seen an SA6(0/1) Celica that had a 1S. Worst case scenario if something really goes wrong spend $50 and a weekend sticking a 2S in it. The 1S is 1.8l isn't it?
    West Australia
    so 2S and 1S-U is identical u say nathan ???
    What about in regards to parts , ie , 2S water pump fits on 1S ? 3S water pump fits on 2S ?
    Johnny boy, I didn't say they were identical! I just said it would be a simple swap to put a 2S in!
    West Australia
    epic fail.....
    What sorta car is it dude?
    Montrose
    Surely you could use parts from a 1S-Ci Camry?
    Later model ST150 Corona also had a 1S.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    West Australia
    need water pump, apparently the biggest wrecking company for toyo's in perth
    "just toyota wrecking"
    "DONT STOCK 2nd HAND PUMPS"
    fuckin great ...
    might have to ebay spec a SV21 pump then ...
    Montrose
    Because pre-loved water pumps are worth getting and all...
    I believe I found a 1S-E in a sv2x camry at a wrecker... central point injection. Was worth chopping the plugs off for whatever reason
    Don't waste your time or money with a 2nd hand water pump, if it didn't leak right away it probably would before too long.
    The 1s water pumps have different part number to 2s, and 3s water pumps. The rear housing on them is different, the front housing and gasket between them (the actual part you'd need) *looks* to be the same so an aftermarket/ebay spec pump for a 3sge *might* fit - I say 3sge to be safe as it's compatible either way where as 3sfe aren't.
    Infact I'd almost bet it would bolt up as the bolt pattern and casting looks the same but I have a feeling the different part number might be because the pulley has a different number of teeth....
    I'm sure toyota can get you the right pump... find someone who can get you trade price
    I am the sun
    Montrose
    Quote Originally Posted by ViPeR_NiPPleX
    1S-Ci. They used these before replacing them with 3S-FC for third-world spec Camry's.
  1. 3SGE differences?
    Last Post: 04-04-2007, 05:46 AM
  2. Differences between RA60/SA63/RA65/MA61 calipers?
    By Shifty in forum Tech and Conversions
    Last Post: 04-01-2007, 12:15 PM
  3. Replies: 0
    Last Post: 30-08-2005, 08:43 AM
