Results 1 to 6 of 6
Thread: wheel size confirmation
    May 2006
    CA
    Default wheel size confirmation
    ive been doing some research and math, and think im good - just want some confirmation
    I am looking at some baller polished wheels
    18x9+41 front
    18x10+43 rear
    im ok with running a spacer, and plan on getting some adjustable suspension goodies in the not-too-distant-future, but i *think* i can get away with these on an otherwise stock x83 (1992)
    just want a final yea or nay before i go ahead and buy them
    CJ
    Default Re: wheel size confirmation
    What size were the stock wheels?
    May 2006
    CA
    I want to say the stockers are 16x6+50
    and i might not have been clear on teh model, its a 92 JZX83 Cressida (in the process of getting the 1jz into it right now actually)
    thanks
    CJ
    they will stic out of the gurads by bout 1 inch each......
    i have 17x8 front, 17x9 on the rear, both with a +45, the front are perfectly flush with the guard.
    the rear i have to run a slightly stretched tyre,
    see my members thread below
    you do realise that using spacers and the wrong offset wheel puts huge extra stresses on your wheel bearings?
    If your gonna do that, then you should look at your bearings and check they are top-notch.
    The wheels should fit, if you don't lower the suspension. You might have to roll the lip of the guards a little since your offset is wrong.
    Save yourself the trouble and buy the wheels that are actually meant to fit on there.
    Use this to work out how much difference there will be compared to your old wheels and then just use a ruler on the car to check it'll work - fool proof
    http://www.1010tires.com/WheelOffsetCalculator.asp
    My KE25 thread
  1. Legal Steering Wheel Size?
    By 011 in forum Tech and Conversions
    Last Post: 11-04-2007, 06:05 PM
  2. Basic Steering Wheel Conversion
    By Andrew162 in forum Tech and Conversions
    Last Post: 23-11-2006, 09:43 PM
  3. Old RWD Wheel Studs / Nuts Size
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 21-06-2006, 04:51 PM
  4. Corona MK11 wheel bearing size???
    Last Post: 06-03-2006, 10:34 AM
