Theres that much talk of this conversion all over this forum at the moment.... USE THE SEARCH BUTTON
ok have an RA23 with a hilux rear end with crappy but bigger than the original drum brakes. I should have chose a diff with disc's but its too late for that now. I managed to steal the model plate off the lux when I stripped the diff out, it was a 1980 RN40, trans axle code is L42 G142. Has anyone else used one of these or similar to this one and changed it to disc's
Any help or information would be appreciated
r31 skyline, corona avanti, commodore, etc etcetcge tctec
you can put your dics on whatever you likeI can put dics's on my Hilux diff![]()
http://www.toymods.net/forums/showthread.php?t=2766
Is also a rather neat, painless solution.
Nikita the RA23 is almost finished.
Thank's tricky didnt see that one!
does that mean out of pure fluke you didn't see this thread either?
http://www.toymods.net/forums/showthread.php?t=18913
with pictures and all that needs to be done with support from pure_in_sanity who has done this upgrade to an RA23 or similar i believe.
WOW
off topic, what turbo is that man? Its FUCKING HUGE!!!
THE OFFICIAL TOYMODS BOGAN
MA61 - sunroof., 7MGTE, 4.11 lsd, w58
MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
yeah I saw that one, didnt read it all the way through, I was just looking to see if any one had done the mod to the specific diff that I had, wasnt sure if all the hilux diff's are capable of that conversionOriginally Posted by barned01
Its a Holset truck turbo. off a 16ltr V8Originally Posted by Robbos_Toyotas
Yeah, great thread that.Originally Posted by barned01
Thanks to all the guys who offered their experience especially Pure_In_Sanity and Robbos_Toyotas. And to GT for making the brackets.![]()
Peter
and you think that will work on a 2l 6?
Infotechplus - brakes working ok mate?
Absolutely Robbo. In fact the engineer complimented the feel and stopping power of the brake setup. He said it brought a smile to his face.Originally Posted by Robbos_Toyotas
Peter
did u adjust the bias? I havent got around to it yet....i might try and get around to it tommorow...
sux being an apprentice - i have to work so many hours to keep my cars on the road, then get no fuckin time to work on em
Sorry for drifting off topic too btw![]()
I'm looking at fitting R31 rear calipers and some 5 stud rotors to my lux diff. SO much easier/cheaper to source R31 calipers than the Toyo ones.
No, I only played around with the handbrake, which is still a bit slack.Originally Posted by Robbos_Toyotas
I know the adjustment is that small bolt head. Inside there are a couple of small balls and springs apparently that control the bias. I'm leaving mine where it is at the moment - if the engineer is happy, I'm happy.
Peter
