VL pumps DONT lift. VLs have an in-tank low pressure high volume pump to do that job. 3 options:
1) put in a lift pump
2) mount the pump below the tank and install a 1/2" feed from the bottom of the tank
3) get an in-tank pump
As for the O2 sensor, you will need to find out what the voltage/current output range is to meet your requirements (if there are different types, they may all give the same outputs), then I would suggest looking at something like an ED foulcan item... they are common as dogs nuts, and relatively cheap to purchase new... plus they are nice and small. DONT get the EA foulcan style ones, they dont last as good as the later model items... they had an issue with them.
A similar year commonwhore sensor would also be likely to work.
Anyone got a part number for 16R rods so I can check these ones in my donk when I pull the sump off??
