Page 52 of 392 FirstFirst ... 242505152535462102152 ... LastLast
Results 766 to 780 of 5875
  1. #766
    Sydney N.S.W
    Can't help with your main question, but as far as the steering column cover goes for Ra 28.
    You can use Ra 40 cover. The difference is a small hole on the egnition side, which is for a hazzards switch, I think.
    Sorry this answer was for the question a the bottom of your post. Soooo long ago.
  2. #767
    Junior Member Grease Monkey Gunna's Avatar
    tasmania
    Thanks mate i didnt know that... + rep...
  3. #768
    KE30 corolla steering column surround works a treat, I used one on my 23 for 3 years.
  4. #769
    tasmania
    Thanks guys...
    What sort of clutch do most of you guys use?
  5. #770
    I currently have a stocker clutch but needless to say I'll be upgrading it. For a NA engine I'd get a custom high-clamp pressure plate with an organic drive plate, but for the turbo engine I'm building it will be a 5-puck sprung ceramic drive plate.
  6. #771
    yucky!! you'll get real sick of trying to drive that in traffic real fast! (if that is indeed something you'll be doing)
    '77 RA28LT #2 ← 2.2L 18RG...
  7. #772
    Sydney N.S.W
    I use a centre forge clutch, nice and easy feel, pressure on the plate increases as the speed gets faster. Has been great.
  8. #773
    Quote Originally Posted by RAd28
    My Supra had one for several years and it was driven daily. You get used to them quickly and then you don't even think about it again.
  9. #774
    I'll go for a twinplate one day.... until then i'll be doing similar to Norbie.
    More puks = less ghey.
  10. #775
    4 puck on the 1G ra28 atm .... meh you get used to it.
    the shock is then driving the mrs st204 afterwards ... nearly put my feet through the floor its that soft
    Black Betty >HERE!<
    (\__/)
  11. #776
    I want a twinplate for the 3SGTE... but the cost factor may play some part in me getting an 8 puck clutch.
  12. #777
    tasmania
    Thanks guys... How would a stock clutch cope behind a 18RG with a bit of work? Its just a daily driver at the moment...
    Cheers, Craig...
  13. #778
    Get a sports clutch... they have a higher clamping force, and arent usually too expensive. They still use a solid friction disk instead of pucks, so are quite drivable and will take a lot more punishment.
  14. #779
    tasmania
    Any sugestions? Sorry guys i dont know much about clutches...
    Cheers, Craig
  15. #780
    i got an RPM clutch installed in mine before i even got the car, 'cause dana and my mate killed the clutch while thrashing the crap out of it before i got back from tassy... (and they wonder why it's never run as good since ) so far i've had no problems, engine is only mildly worked... just sounds good i think from memory it was less then $200 supplied...
