Page 304 of 392 FirstFirst ... 204254294302303304305306314354 ... LastLast
Results 4,546 to 4,560 of 5875
  1. #4546
    88210 intake manifold is the really long one, which uses a piece of pipe and rubber hose joins as the balance chamber.
    I used the 88250 intake manifold on my old RA28 in the past, with low profile K&N filters (the 25mm thick ones), and it fit - but it was close.
    I then went EFI and never looked back.
  2. #4547
    Although the ramflos in mine did disintegrate, if I had regularly checked and re-oiled them, I would not have had any dramas. The filter elements themselves are in the vicinity of $10 each.
  3. #4548
    Sep 2011
    hey guys - I am about to do the 22R ignition upgrade on my 18RG.
    Picked up the complete dizzy/ignitor/coil from a 22RE.
    Just confused with the wiring diagrams in the guide thread. My ignitor has a pink, yellow and black wire coming out to a plug and also a white and pink to the dizzy. All the diagrams i find dont match these colours. I figure that possibly the correct colours are on the other side of the plug which is unfortunately wiring that i do not have. Can anyone point me where i might be able to figure this out or tell me where those colours go on their conversions?
    18RG RA28
  4. #4549
    Post a picture up of what you got mate.
  5. #4550
    Sep 2011
    Pic quality is shocking i know - I broke my camera a few days ago.
    the ignitor has 2 wires running to the dissy - white and pink
    and two to a plug - pink, yellow and black
    plug looks like this
    I assume they will be earth, power and a trigger for the coil? just not sure which is which and cannot find a wiring diagram with those three colours.
    18RG RA28
  6. #4551
    These usually earth through the bracket mate.
    It seems to be quite similar to the 18RG one in terms of wiring colours
    In which case, black is Coil negative, yellow is tacho, pink (which I could possibly have mistaken for Light brown) is ignition.
    In the 18RG one, the circuit board inside the ignitor had the pins labelled, maybe open it up and have a look if you want to be sure.
    Is there a another connector from the ignitor which the coil connects to?
    The two wires going to the dizzy you don't really have to mess with, just keep them as they are. (They shouldn't connect to anything else)
  7. #4552
    Sep 2011
    only the 5 wires i described come out of the ignitor. Will open the box up today and see what i can find.
    nothing labeled in there. Will try and find a standard 22re and have a rummage through the engine bay.
    18RG RA28
  8. #4553
    Aug 2010
    S.E.Q.
    Oil pumps again boys & girls
    It is as I thought. There is another ToJo pump with the same gears as the 18RG. I have one, trouble is I dont know what engine it is out of.
    We were at a clearing sale & my mate Ken bought a $2 box & in it was a Toyota oil pump of unknown origin which he did'nt want & gave to me. I thought it would be good to look inside it & lo & behold it has 30 mm gears the same as an RG. I put the outer rotor into an 18 rc pump & it spun with the inner driving it just like a bought one.
    This would alow you to easily replicate an RG pump with one of these, an RC pump & make a spacer the same as an RG. Too easy. No lathe work.
    I just wish that I could identify the pump. If there is one there must be more with the same guts.
    It is gear driven off the cam, has an aluminium cast pick up with a four bolt attatchment to pump & the oil out has a screw in connection for a pipe to the block.
    Maybe an old cruiser six cylnder.
    Owen.
  9. #4554
    Feb 2012
    Australia
    Take some pictures of it, people may be able to Identify it easier then =P
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
  10. #4555
    Aug 2010
    S.E.Q.
    Yeah, in about a week. I am a dinosour with that stuff.
    My Mrs. is the picture poster person in our little family & she is away working.
    I can play spider solitair & type shit with one finger but someone keeps moving all these letters about. Its worse than a Rubics cube.
    Owen.
  11. #4556
    Quote Originally Posted by S. Lowlux View Post
    Owen.
    Hi buddy,
    Would bet my left nut it is from a 4m. Ive got a manual here that shows it to be the same gear pattern and works in the same way as the 18r but could never get my hands on one to confirm. If i can find the book i'll let you know, but i havent seen it in years.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  12. #4557
    So after a bit of internet sleuthing if it is a M series pump the ones to find are the pumps from M or early 2M motor. The trochoid pump (one we are after) is only on the M and early 2M motor and changed to gear type on later 2M and all 4M models.
    Source doc
  13. #4558
    Aug 2010
    S.E.Q.
    Wallaby ferked, if'n bEn is not correct in identifying it as an early 4 M pump 65 - 73.
    I found an online manual that showed the exact same pump.
    Pity its so early as that means that it won't be common any more.
    Owen.
  14. #4559
    sweet, saved that one again Mate if you look you can find 4m's in crowns and mark II's. There's a wreckers i know of that loves having old cars. In fact, if it was made later than 1990, they probably don't have it....... Probs going to go check them out again on the weekend. Will see what i can find.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  15. #4560
    Top End
    Thats all good and well but the pumps we need i believe are 1M and 2M pumps or 3m (2000gt motor) all from mid 60s to early seventies and extremely hard to get parts for
    in all honesty i think you will have a better chance finding a true TRD 18rg oil pump before you find a good condition early M pump thats useable
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
