Page 205 of 392 FirstFirst ... 105155195203204205206207215255305 ... LastLast
Results 3,061 to 3,075 of 5875
  1. #3061
    Oct 2008
    der............
  2. #3062
    Oct 2008
    I believe it is a stock engine but it has twin webbers not EFI and it has scorcher elec ign so maybe somethings a bit non stock with the cams.
    The engine ran but has little compression
    35, 60, 60 ,60.
  3. #3063
    Sydney N.S.W
    I would realign the cams, with the cam notch's at 12 o'clock and the confirm the dizzy is at no. 1 TDC. Also confirm the the crank is on compression stroke and not 180 deg out.
    Some times these motors are dialed with one of the cams (exhaust i think) slightly advanced.
  4. #3064
    Aug 2009
    Quote Originally Posted by thdevilshands View Post
    35, 60, 60 ,60.
    Hey guys
    Had a closer look at the timing on the 18RGEU today
    with the dizzy rotor at no 1 (TDC) the two cam shaft indicator marks are at about 11 oclock
    as I spin the crank and the dizzy rotor to halfway between cyl1 and cyl3 the cam mark on the intake is at 12:00 and the exhaust is at 1:00
    I believe timing should be 12:00 on both in and ex at TDC???
    Thanks, Jon
    If the Cam timing is out, this might explain the low comps, however looking at the numbers it does not look good. Reset your cam timing as if it were a standard motor (ie 12:00 on both at TDC) and check the valve clearances to make sure they are not riding the valves open and then do a dry and wet comp test with the motor warm with throttles open and ign wire off (wet is two squirts of oil in each cyl).
    That'l do for starters and let us know how you go.
    Rgds, Willofan
  5. #3065
    Oct 2008
    Thanks, I'm having problems finding a manual for this engine and know very little about twincam motors (ie first time inside one)
    For the Dizzy #1 is at about 5:00 or 7:00 I think - Down the bottom anyway Is that right or is it 180 out?
    Hot and Cold Valve Clearances are?
    Will I need to take the whole front timing cover off for Cam timing to check timing chain position on crank?
    We have to remove the head anyway to check what the bores/rings/valves are like so will prob do that before re setting the timing.
    So in summary:
    To remove head I just need to time to #1 TDC
    *** Unsure if this bit is required when removing head *** Secure Timing chain (tie wire either side?? wedge??)
    What is used to secure chain and does it even matter if chain moves)
    Crack Big Cam Bolts
    Remove Cam Gears
    Crack head bolts
    Remove head
    Does the timing chain tensioner between the camshafts need to be removed or can it stay on the head?,
    Is there a sequence for removing any of the timing tensioning stuff??
    Thanks, Jon
  6. #3066
    http://members.iinet.com.au/~stepho/manuals/R/
    oh damn, its gone
    If i can find my green book i will scan the appropriate pages dood.
  7. #3067
    Oct 2008
    Legendary Stuff!!
  8. #3068
    Sydney N.S.W
    Wait for the green book scans.
    this will show you the crank positions and the top chain gears(for dizzy) as they need to be aligned also. the gears behind the timing cover have a dot to shown positions.
    So the bottom end need setting then the cams.
    good luck
  9. #3069
    Hey man,
    I couldn't find my books, but did save all the pages from the old site and have zipped them into here.
    18R/18RG Green Book
  10. #3070
    Aug 2009
    Does anyone have a spare modified wet mid sump larger pan for an 18RG with an extra 2ltrs of capacity, or know someone in Sydney who can make one from the spare std sump I have???
    Appreciate any help as I need to get this going in less than 6 weeks.
    Rgds, Willofan
  11. #3071
    Ballarat Vic
    High energy sumps in Melbourne should be able to help.
    Roscos
  12. #3072
    Oct 2008
    Thank You 7M-GTE MX73
    That's going straight to the pool room.
    I'll let y'all know how we go with it.
    Cheers, Jon
  13. #3073
    Magic, I lost half of mine when I finished up a site contract...
  14. #3074
    nice datsun Backyard Mechanic TRD184's Avatar
    Jan 2009
    New South Wales
    anyone else read "modified retro cars" magazine? gorgeous UK TA40 with a rover V8 in there. thought some may be interested
    my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
    It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
    - Hit it.
  15. #3075
    Aug 2009
    Quote Originally Posted by TRD184 View Post
    Is this the same one??You can see his build right here, awsome engineeeeering
    http://www.toymods.org.au/forums/showthread.php?t=54068
    Rgds, Willofan
