Page 10 of 392 FirstFirst ... 891011122060110 ... LastLast
Results 136 to 150 of 5875
  1. #136
    Witzl, I'm pretty sure that the question mark on your photo of the GEU intake plenum is part of the idle up mechanism for airconditioning.
    (\__/)
    (")_(")
  2. #137
    Thanx Witzl. Going to order what I need and get this thing running again.
    Have a question for anyone that might know this. I have notice that most the 18r-g* on here and other sites have a different rocket cover than the one I have. I am interested to find out what it is off (18r-GE ?) Nothing gained, nothing lost?
    Thanx for your time
    Adam
    KE-30 Corolla
    18r-GU 88250 2lit Twin .45 Webbers
    Edit: picture urcl
  3. #138
    Steve, i realised exactly what you just said whilst driving to work this morning thinking about putting the aircon on the car
    It uses a VSV to open the big air bypass port on it - kind of like an amplifier
  4. #139
    Norbie: that's a very clean looking workshop floor you have there under the eyesore - would you like some used diff oil (mixed with unknown waste solvents) and wheel-bearing grease to return it to it's native oil-stained finish?
  5. #140
    Forum Member Grease Monkey scootaphill's Avatar
    victoria
    Karl if you have the EPC you could use the pics to determine where it goes and what it does via part number etc...
    or i could go have a look... *walks to shed* mine connects to vac advance on dizzy..
    ps howd the wiring turn out?
    ON HOLD Current Project 1UZ-FE Powered Buggy
    Last Project 18R-GEU time to tinker
    EDITED ITS ALL VERY LAMO
  6. #141
    or failing that, just buy my commodore, it'll make it messy as fuck
    The boobs are back
  7. #142
    Corolla Collecter Backyard Mechanic Trent-KE30's Avatar
    Hey Adam, per your KE30 18R-G how hard was the conversion?, got any more pics?
    First time ive seen this done,
    Trent
  8. #143
    Sheebz Automotive Grease Monkey Gleno28's Avatar
    Quote Originally Posted by KE30_18r-gu
    Thanx for your time
    Adam
    KE-30 Corolla
    Hey Adam, your cover matches the one i had on the 18RGEU (88270 head), but... also matches one off a 18RGU (88253 head), but i'd say later gen 18RG's, i'll see if i can get some pics up
    18RGEU
    18RGU
    Glen.
  9. #144
    What you can't see is the floor under where the Supra is usually parked. I have oil stains aplenty, don't you worry.
  10. #145
    The cam covers with the "DOHC" raised text and oil cap on the intake side are from 18R-GEU's..... it's not at all uncommon for cam covers to be swapped around though, as some people actually seek out the 18rgeu cover for it's "DOHC" label.
    Phill....
    that's pretty weird how your's connects to the vacuum advance on the dissy - in fact that's just all wrong by my understanding.
    Vacuum advance dissy's are supposed to be connected to a vacuum port that only gets vacuum when the throttle is JUST cracked open. It shouldnt have vacuum all the time.... otherwise at 5000rpm when you lift the throttle off, you are at max mechanical advance due to the weights, and then suddenly it advances another 10 or so degrees on TOP of that max advance..... not cool!
    I have used one of the 2 ports on the throttle body as these are just in front of the butterfly, as described above
    I'll try to draw up my conceptual understanding of the vacuum system...
    Last edited by The Witzl; 08-02-2006 at 03:00 PM. Reason: added my beautiful diagram..... woot
  11. #146
    victoria
    This is not really the place but...
    What sort of valve to piston clearance (on overlap at 10deg) are you guys running... im moreso intrested in the INTAKE valve to piston...
    im also intrested in the availability of stronger after-market springs
    phill
    PS karl my dissy has two vacum hoses. if 1 is closest to the body and 2 in furtherest from the body the formentioned vacum line is connected to number 2...
  12. #147
    i run the springs by performance springs, PN RR4,about $150 a set, can hold my valves at over 8000,
    they are doubles too
    The boobs are back
  13. #148
    victoria
    thats great but what piston to valve are you running on the intake?
    ps wahst happened to your avator
  14. #149
    Does anyone have or know where i can get a copy of the 18r engine manual.The older green covered one that covers 18rgs.
    Thanks Nev
  15. #150
    Junior Member Domestic Engineer tricky's Avatar
    Yep. They pop up on e-bay frequently. Probably one a week or so.
