A thought!! A common cause of dense white smoke from the exhaust system is 1- TA faulty brake booster if fitted allowing back sucking brake fluid into the exhaust system or 2-the PCB valve allowing a bypass of the EMC and flowing a fat mix of lean oil into the exhaust system. Check both levels!
) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
) flows into the intake, usually before the throttle, not the exhaust (exhaust gasses in your oil system will cause it to pressurise and kill a motor before you can say WTF!!)
