Results 1 to 10 of 10
Thread: Mark II steering/tie rod adjustment
    Lillehammer
    Default Mark II steering/tie rod adjustment
    Hi
    I have change the outer tie rods on my mark II, but now i cant get the steering normal again.
    i have measured the distance between the front wheels, on the back and front of the rims, and adjusted the tie rod ends so the distance between the front and rear of the rim is exactly the same. I guess the distance between front and read of the rim probably shouldnt be exactly the same, since the car now is a real bitch to drive, its ok when drive straight forward, but its over sensitive on the sterringwheel when turning even a tiny bit, and it shoots to the side when touching the steeringwheel.
    does anyone have any thoughts about this, or know what the distance should be?
    i have checked all the other ball joints and tie rods, and thats all fine.
    Thanks for all ur help
    Junior Member 1st year Apprentice clancey's Avatar
    May 2006
    Default Re: Mark II steering/tie rod adjustment
    Generally when I've replaced tie rod ends I've marked the thread on the tie rod rather than measure the distances between the wheels. As you've described is extremely had to align the wheels together with the central steering wheel position without the proper equipment (Not that this really helps you now).
    I've always had a wheel alignment done straight after replacement anyway, keeping the tie rod ends in approximately the same position just makes it easier to get to the shop.
    Clancey
    Lillehammer
    Thanks for ur answer
    Yes i use the same method too, measure and mark the tie rod before i take it off, but this time the steering was strange so i started adjusting it, before i found out the other end had to be replaced too, so i messed it up.
    the tool i borrowed to measure the distance between the front and rear of each wheel should be good enough to get the steering correct, but since im not sure what is the correct distance between front and rear that really doesnt help much either.
    anyone have a shop manual or something where it says the distance on some kinda car? of course the distance on a mark II would be best, but something is better than nothing
    May 2006
    I believe the factory settings is to have between 1-3mm of toe in, they don't specify exact measurements between the wheels for obvious reasons.
    Clancey
    Lillehammer
    thanks, i will give that a try.
    toe in? my english isnt so good so im not sure what that means, what end of the rim should have the smallest distance?
    You mark the thread on the tie rod with some white out before screwing the tie rod end off, that way the new ones are pretty damn close still needs an alignment after none the less
    I am the sun
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    The distance between the front of the rims should be 1-3mm smaller than the distance between the back of the rims. If youre running wide tyres id say 3 is better than 1.
    ie in front
    .....__x-3 _
    ../_/__x _\_\
    to rear of car
    my drawing is crap but maybe you get the idea.
    Quote Originally Posted by MarkIIRx12
    Lillehammer
    thanks again
    I adjusted it with approx 2mm shorter distance on front, and it got pretty good to drive now. of some reason the car still wanna go a little to the left, so i guess i will do an wheel alignment soon to get it perfect.
    thanks for all ur help
    May 2006
    Nicely done andurils_sheath, I couldn't have put it better myself.
    A bit of rep is always a nice way to say thanks
    Im still just a......... Backyard Mechanic NoRecall's Avatar
    Tasmania
    You will have trouble getting it to be perfect.
    Both mk2's i have owned have allways had a slight stear-to-the-left sindrome. As far as i knew it was designed like that so if you fell asleep at the wheel there was less of a chance of you vearing into oncoming traffic.... but i could be wrong. However a tyre place i took it to still couldnt get the slight left steer out of it with a eletronic aligner.
    From Tassie?
  1. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  2. NEEDED!: gx71 mark II wiring diagrams!!
    By sticky667 in forum Tech and Conversions
    Last Post: 06-09-2006, 04:57 PM
  3. camber adjustment for st162
    Last Post: 29-04-2006, 07:38 AM
  4. Camber adjustment jza 70 - wearing outside edges
    By jza70-mel in forum Tech and Conversions
    Last Post: 27-02-2006, 01:04 AM
