Results 1 to 12 of 12
Thread: HELP!!!! 7MGTE issues
    drunken escapades Conversion King fatboy13's Avatar
    Default HELP!!!! 7MGTE issues
    Ok,
    so today ive had a pretty shithouse day. I woke up and found out i had a flat battery so i jump started the car. Now usually when i start the car i have to crank it twice for whatever reason, but today it took forever to start.
    Once i got it running it was idling really rough and pumping alot of black smoke out the exhaust and also out of what seemed like the turbo. If you rev the car then once it gets back to idle it stalls. When you start it again it will stall immediately.
    Ive checked the cooler piping adn it all seems to be fine, any ideas???
    Help please!
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    Default Re: HELP!!!! 7MGTE issues
    map sensor or afm, o2 sensor, really low voltage, or a cooler pipe etc is blown off if you have an afm.
    Western Aus
    cooler pipe/vac line will do that to ya...
    sounds like your AFM might be unplugged too?
    Elmo.
    Ill have a look at that stuff when i get home tonight.... if light and weather permit that is.
    Thanks for the ideas and ill let you know what happens
    JZA80 Convert Backyard Mechanic
    Yeah, sounds like AFM unplugged or a huge leak in the intake system after the AFM somewhere.
    alright well everything seems to be plugged in and i couldnt find any leaks or cracks in anything.... so im thinking that something must be pretty terminal
    Im going to pull the intake from the turbo tomorrow and see what it looks like in there, im expecting a mess.
    any other ideas for if thats fine
    GT4 Freak, and Conversion King Squid's Avatar
    I would hazard a guess that if your battery has suddenly gone flat, you have probably blown and alternator or regulator, the car isn't getting enough spark, therefore the fuel isn't getting completely burnt, and cant sustain anything more than idle.
    Check for 14v across the battery when running and a minimal movement (max 1V) when you turn the lights on, from which it should quickly recover.
    As cool1 would say, check your earths as well.
    Edit -> also if the battery is fubared it may be taking your charging circuit to a short circuit, which would divert needed power away from the nice things like spark plugs etc
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    awesome thanks for that... hopefully its going to be something simple
    Pukekohe
    Quote Originally Posted by fatboy13
    Help please!
    I had a similar fault but worse is when it happens in rush hour traffic. Several weeks after swapping all sorts of things, I tried the water temperature sender for the ecu. Yes; for the ecu.
    They have a separate sender for the gauge. It would appear it would "tell" the ecu it was cold so it would enrichen the mixture..... Sounds similar to what you may have. The sender is on the thermostat housing and has two wires running to it - one Brown and one Green. It is easy to get to and would only take 15 mins to swap.
    Just something else to try.
    mine only has 1 wire running to it......
    Western Aus
    thats your guage temp sender, should be yellow with a green stripe through it.
    hes talking about the other sender.
    Elmo.
    ok thanks i checked the other one and its fine....
    I pulled most of the intake side of things apart today and the turbo was loose on the manifold which fixed a fair bit, also adjusted the tps and have the car running.
    Its blown both the gasket between the head and the manifold, and the manifold and the turbo so ill get these replaced. Also has a leaky injector which is causing some problems.
    And lastly the intake piping from the cooler to the turbo itself was really loose on the turbo end of it... so i tightened that up.
    Car is now running nicely again other than the popping noise from the blown gaskets.
    Thanks for all your help guys and ill let you know how i go once everything else is finished
  1. 7MGTE running rough, SAFC Related
    By doobs in forum Tech and Conversions
    Last Post: 19-06-2006, 10:53 PM
  2. 7mgte a340e transmission installation issues
    By 7mgte mx73 in forum Tech and Conversions
    Last Post: 01-01-2006, 06:23 PM
