I just got hold of another fuel line the same as the original and mounted them together with double saddle clamps (try to avoid the lines rubbing on each other).. Not sure about brass, ok for fuel fittings. I know that fuel lines are a pain to remove from a car at the wreckers but if you can do it carefully you end up with a matching pair of lines that look the same and really neat. Remember don't let them rub each other or the body or over time they can fail. Have a look how car manufacturers mount them.The other thing to take into account is the fuel volume that will be going through them. Another thing is to use EFI rated flexible hose on each end of the steel and not just use the old carby hose as it is not rated at the pressure required for an EFI engine.
