Results 1 to 15 of 16
Thread: RT142 + T series??
    Junior Member 1st year Apprentice Gilly's Avatar
    Default RT142 + T series??
    basically curious to know whether a t series diff will fit a corona (mounting points), i', pretty sure i have read before that some models were equipped with a T series.
    i did i search and in the diff info excel sheet that was put together it stated that the disc setup would fit "T" series diffs. pardon my ignorance but does this mean the RT142 could physically take a T series from an RA40 or similar. I (obviously) rarely venture out of the realm of 70's and 86's so i'm feeling awful noobish
    basically curious to know whether a Tseries diff will fit a corona.
    i like to say T series a lot
    T series
    Default Re: RT142 + T series??
    Locally-delivered RT142's are either live-axle Borg Warner, or IRS F-series. I've never seen one with a T series, but that's not to say you couldn't adapt one if you were really keen. Get your tape measure out!
    supposedly the borgwarmer diff from an RT142 bolts straight into an RA40 (mounts and all in the right spots or so the rumour suggests) - so it's likely that the T-series RA40 diff bolts into the RT142.
    If the target RT142 had rear disks, you'd have to put those disks (and associated hardware) onto the RA40 diff. Going from disks back to RA40 drum rears would be a bad thing mmokay?
    i love you chuckster.
    many thanks
    just hang onto that love until you've measure both diffs
    T'ville, QLD
    is the T stronger than the bog warmer? i wouldnt have thought so
    are you only doing this cos you have a t series diff? unless its an ra40 diff the you car going to have to re bracket it, which then asks why not hilux diff?
    2T out 4A in....
    the T would be the stronger of 2 weak diffs...
    Junior Member Grease Monkey Mr Multivalve's Avatar
    Quote Originally Posted by Gilly
    T series
    Hey Gilly,
    This might help give you an idea of the comparison between an F series and T series diff.
    http://toymods.net/forums/showthread.php?t=21842
    Ciao
    Corona Creed:
    Good to Drink, Great to Drive, keep them separate to stay Alive!
    south austraila
    The diff's in All the RA40, RA60, RT141 & RT142, Use the same Hanger's...
    So all are interchangeable, that is swop the over ...
    Project: '82, GA61 XX
    I thought the RT141 was a solid axel not IRS ?
    Corona Creed:
    ST141 is solid axle, RT142 is either solid axle or IRS. This is for local models only, imports are a different story.
    Ahh ok I thought all rt142's were IRS but obviously not.
    Corona Creed:
    top work gents i now know a RA40 diff will go into a rt141
    it was for a guy was piecing a diff together for. it fell through BUT i know now, and a corona is now a very driftable future build for me now
    Junior Member Backyard Mechanic SIKTOY's Avatar
    This is a question I was going to ask but in reverse I want to put a F series out of an import rt142 into my RA40
    Thanks for the info guys
    Ben
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    Tasmania
    F series diffs in the RT 142 are IRS as where the RA40 have a solid axle so if your a good fabricator/welder then the task is at hand if not stick to the solid axle or buy a RT 142 Rona.
    Cheers Brett.
  1. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:51 AM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
