Results 1 to 6 of 6
Thread: How do you tell the differance between T and S once out of car?
    Junior Member Grease Monkey crostek's Avatar
    Default How do you tell the differance between T and S once out of car?
    How ?
    I was looking at buying a T series diff from wreacker but dont know how to tell the differeance between a S series diff and a T series Diff once they have been removed from a car, does any one have any phots of there diff?
    Shane
    Default Re: How do you tell the differance between T and S once out of car?
    The carrier for the t has 10 bolts wheras the carrier for the s has 8 (this is on the flange holding the carrier to the housing).
    Otherwise the s centre is 6.4" and the t is 6.7"
    ps you should have searched on this
    Thanks for the help.
    Try to search but as T and S are so commonly used it would not give a result.
    Act
    you could also measure the S series crown wheel should be smaller than the t sereis. I forget the difference of the top of my head
    Yeah you just need to put in a bit of effort on the searches, like try using ae86 + diff or or diff + series or something like that. Sure you have to filter through a fair amount of junk but it helps to cut down on threads being repeated (thus less junk to filter thorough when searching).
    Quote Originally Posted by TheStitt
    I probably should have been a bit more explicit in what these measurements were (they refer to the crownwheel).
    Act
    thats what i thought a E is 7 inch isn't it
