Results 1 to 7 of 7
Thread: Silvertop TPS Settings
    Junior Member Carport Converter DaveW's Avatar
    Default Silvertop TPS Settings
    does anyone have or know where i can find the settings to set the Silvertop 4ag when i put it back on?
    Dave
    Add Lightness! Grease Monkey spectral's Avatar
    Default Re: Silvertop TPS Settings
    Hi mate,
    See attached scan from AE101 manual
    Spectral
    cheers spectral spot on the money!
    Can I ask: What would indicate that I need to check this?
    I have taken my ST from 116k km to about 150k km over the last 2 years.
    If the TPS hasn't been removed from the end of the throttle bodies, and the ECU isn't spitting any error codes, then there is no reason to adjust it.
    To the best of my knowledge the TPS is just used as a measure of how quickly you are modulating the accelerator. The actual load on the engine is calculated from the MAP (blacktop) or AFM (silvertop) sensor.
    You can disconnect it entirely and the engine still runs, its just got a slow response to throttle variations.
    Thats my experience when playing around with my blacktop anyway.
    Silvertop has no MAP. It runs AFM. If that pic you posted is from the Blacktop Manual that will be the reference to MAP (Blacktop runs a MAP.)
    Yeah I know that the ST doesn't run a MAP. I mentioned the AFM for the ST in my post above.
    The pic I posted doesn't have anything to do with a MAP? Its just the resistance of the TPS sensor as the throttle butterflies open??
  1. 4agze TPS - fault & setup
    By AE101LEV in forum Tech and Conversions
    Last Post: 24-10-2006, 06:36 PM
  2. TPS Idle Switch
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 19-03-2006, 05:44 PM
  3. Urgent Help Please - TPS - Car Undriveable !
    By ra23celica in forum Tech and Conversions
    Last Post: 10-03-2006, 10:40 AM
  4. Full-variable output TPS - what cars ??
    Last Post: 20-02-2006, 11:59 AM
