Originally Posted by
DeftAnesthetik
from what i understand 20v head will go on ANY 4A block just make sure you use the 20v HG. if your going to boost all you really need from the ZE would be the pistons. 20v block(along with later ZE block) are "upscaled" from previous blocks as they have oil squirters for piston cooling.
note: i am in no way talking about Blacktop as it is a completely different monster all together.
EDIT: just realized your talking about saving the hassle of re-routing cooling, unfortunatly changing the 20v to a RWD layout you will have to do something like Sam_Q did or similar. (like i did). just to let you know though.. it seems like a lot to do, but it really is not. if you had the parts made up that you need its less than a days worth of work to put it all together.
