Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: ff to fr how hard is it
    tasmania
    Default ff to fr how hard is it
    gday guys i have a celica st162 has a 4agze engine its not a bad set up but its front wheel drive and id like to get into the drifting scene what would i need to do to go rear wheel would it be alot of work and whats the price range thank you
    Default Re: ff to fr how hard is it
    Buy a different car. You'll spend $30 grand easy setting a ST162 up to rear wheel drive. Just thing about it, you need to cut a transmission tunnel. Setup a rear diff and drive shafts, the fuel tank would probably be in the way and you'll need new rear suspension. You'll need a new engine xmember, engine mounts, sump, gearbox, need i go on. And nobody would touch the dam thing anyways, its pointless. Buy a rear wheel drive car to start with.
    agreed. it's cool and all but all in all it's a bit of a waste of money. maybe an RA celica or a supra, or older corolla, soarer?
    Hello.
    tasmania
    yeah tanks for that guys i thought id ask befor i tried to do it and now i see your point i wont bother ill start hunting down a rear wheel i like
    Yes, best to start with a RWD. It could take weeks of discussion to just cover why it's so expensive.
    Just get another ST162 engine & gearbox, and graft it into the rear of the car.
    It'll be 4WD, and have double the power of a conventional FWD or RWD car.
    www.billzilla.org
    Toymods founding member #3
    tasmania
    i actually saw a car like that in highoctane it was an old corrola it had an engine in the front and back
    User Conversion King
    NWA
    or buy a MR2 and graft the rear end of that onto the rear of your celica.
    hello
    I don't want to be a Domestic Engineer bnicho's Avatar
    Quote Originally Posted by toyota-celica
    gday guys i have a celica st162 has a 4agze engine ....
    How come an ST162 has a 4AGZE in it? Seems like a stange conversion?
    Brett Nicholson (bnicho) - Greendale, Victoria
    I own Corollas, Crowns, Prados and
    Various leaking British things...
    AT162 sounds like it they exist in Jaaahpan and export to asian market..
    i suggest take out engine and chuck it into a rear wheel drive corolla or older celica... (not the RA40 though or anything newer)
    victoria
    just graft a rack and pinion set up on the rear, hook up a steering column and flip the seat around. then just drift it in reverse gear. easiest way i reckon.
    Drift barge master Backyard Mechanic orestes's Avatar
    Queensland.
    or Just sell your car buy an ST165 GT4, and disconnect the front transfer box ?
    Western Aus
    yeah, buying an ST165 rear subframe would be a start i guess.
    dunno if anything would bolt up though.
    would be awesome to see though
    Elmo.
    upgrade the engine to GT2 spec (turbs, I/C, etc.) so it's got good power, and make damn good use of the handbrake! who said FWD's (FF) can't drift?
    TRIKKE | Video
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    Quote Originally Posted by celicapain
    Then you'd be drifting a REAR engined rwd - even worse than trying to drift an mr2.
  1. 4agze hard to start and then stalls
    By wiso in forum Tech and Conversions
    Last Post: 07-12-2006, 11:31 PM
  2. Is it hard to polish an alternator?
    By Assailant in forum Tech and Conversions
    Last Post: 04-07-2006, 01:58 AM
  3. 3SGTE Hard to start
    Last Post: 27-01-2006, 11:16 AM
