if you want the stock ECU you need the stock dizzi.
I've got some pics somewhere of a 3SGE with the dizzi mounted onto the front of the engine (using simple dog tooth gear to connecto the two and a big alloy plate to mount the dizzi.
lemme look and i'll update the pic.
If you went crank-angle sensor, aftermarket ECU and waste-spark ignition then a simple 32-1 wheel on the crank would be the go.
edit: clicky to find post in the RA40 dedicated thread.
relevant pic:
TerryO (member on this forum) did the mechanical work i think.
