Sikaflex is what we used to use on the formula ford, assume you are also going to plce washers under each rivet as this also helps strengthen join and slows fretting of your panel.
Reagrds
Greg
Mega poxy is also used in compressed fibre cement facade sheetings on buildings.
Were talking 9mm concrete sheets nearly at 10-20 stories high![]()
I can get for you through my work (CSR) at trade.
1 litre kit comes in two containers you mix together.
Trade $30.00
might be able to do better ...![]()
Black Betty >HERE!<
(\__/)
Reagrds
Greg
71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
Too many cars so little time
Yup, was going to suggest this also.Bill I have used 8115 3M panel bonding adhesive here on a few projects to good effect.
Major car manufacturers are starting to use this stuff to lower prices.
http://solutions.3m.com/wps/portal/3...izePageHandler
Daily: Toyota '05 Rav4 Sport
I've been told Sikaflex is what holden use to keep thier commodore firewalls in. It's funny even if it's not true.
Hello.
i believe it is sikaflex.
Yep I would use Sikaflex as well. i have used it in similar situations and it work a treat.
Todd
Hot GLue FTW.....
...... butt scratcher?!
Thanks for all the advice guys, I've got a lot of things to research now.![]()
www.billzilla.org
Toymods founding member #3
hopefully NOT my suggestion.....
i was just posting to be able to find this thread in the future... some good products mentioned here!
Bill, I work for Iveco trucks' assembly plant, the american model has an aluminium cab and they use a white compound to stick the roof on before they spot weld it, if your interested I will write down the name of the product for you.
found out the name:
Cemedine EP210 made by a company called Henkel, good luck with it
Ta for that mate.
www.billzilla.org
Hi Bill sikaflex & simpson are good we use these on buss,s from gluing floor down , alum & fiberglass sides , plastic ect you dont need to use rivets , the only time i have seen it let go is the surface was not prept corectly , use the cleaner & primer to suit .... their is different grades & you can get tubes to suit silicone gun ....
oh & if you have to remove the pannel at any time you will destroy it as this stuff is 100% better than sh*## on a blanket .....
Keith:![]()
Loctite do a large range of adhesives. Give there tech line a call and see what they can offer.
Phone: (61) 1300 88 555 6
Alot of there stuff isn't easy to find info on but if you ring the tech guys they should be able to suggest the best stuff they have.
What about the adhesive that PRB use to glue their Aluminium Honeycomb Monocoques together for their clubmans?
