Results 1 to 15 of 24
Thread: 3tgte ~ High mount or low mount turbo *Pics Added of high mount built*
    I would like to be a Backyard Mechanic 3t-RA40's Avatar
    Default 3tgte ~ High mount or low mount turbo *Pics Added of high mount built*
    Alright, the time has come, mainly due to a small exhaust leak and on closer inspection cracked mainfold, to change/replace the standard 3tgte exhaust mainfold. I'm still in two minds as wheather to high mount or low mount the turbo. Looking for peoples experenice in what they're used. I will be making the mainfold myself (as I do with most things). Also what internal dia steam pipe will best suit. I hope/know Yellorolla will comment, but also looking for others.
    Neil.
    RA40 3t-gte. Haltech fitted.
    Power - 229hp at 17psi
    Default Re: High mount or low mount turbo
    hey super neil!
    i reckon alot of it is personel preference.
    high mount - look cool/rice, better clearance for turbo, straighter shot for airfilter, heat close to bonnet paint.
    low mount - stealth, easier dump pipe, perhaps less bends in manifold- easier to make?
    any way, that t51 will probly have to be highmounted to fit hehe
    disclaimer - i know nothin about anything, all advice should be immediately dissreguarded before it permanently makes you less intelligent.
    Stew
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    low mount helps get the heat from the turbo out of the engine bay because of the air coming under the car.
    Quote Originally Posted by Toy77
    hey super neil!
    Stew
    Hey super Stew, that sound better than mine
    I think the difference to make/bends will be stuff all. I'm leaning towards high mount as I can then run heater, a/c lines and wiring along the chasie rail giving a bit better clearance and every thing will be getting wrapped and shielded.
    Neil.
    Quote Originally Posted by Jackel
    I was thinking where the standard carbie feed comes into the engine bay I could use with some ducting on it to push some of the heat down/back towards the fire wall. I guess this could be used in high or low configuration.
    Neil.
    Default Re: High mount or low mount turbo *Pics Added*
    Ok, I decided to high mount turbo.
    I used mid steel steam pipe, and even though most welds were good I decided to flap disc them smooth (the whole maifold actually). The internal welding I have not flap disc yet that's tomorrows job and the turbo plate is not getting welded on until after that is done.
    After I ran it on the car for a week or so I'm sending it off the get cermaic coated by Procoat Ceramic Coating - Unit 1 / 1 Clare Mace Cres, Berkeley Vale NSW 2261 02 43889946 or 0407895044. Real nice guy to talk with and also sponsors Shane 1JZ 747's Cressida.
    Neil.
    victoria
    Default Re: 3tgte ~ High mount or low mount turbo *Pics Added of high mount built*
    nice job, very clean for a home made special!
    Good one Neil - that's about how I'd have done the pipe layout. Don't forget to brace the turbo/manifold to the flange plate and to the engine mount.
    Quote Originally Posted by YelloRolla
    Wasn't to sure about the bracing. With the current turbo I have, in the standard position, the bottom braket was remover years ago. If I just brace the turbo flange back to the head flange do you think that may be enough or should I really do both.
    Neil.
    Junior Member Grease Monkey rke_011's Avatar
    sa
    i wish i had the cash for a turbo upgrade on my 3t
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    would u be interested in making me 1 of these thanks
    just put in 2 braces from the turbo flange to the no 2 n 3 runners, that should do it nicely, unless your running somethin crazy like a t88
    lol
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    lol
    t88 crazy well my mate just farked it off for a cool spl t51r
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    T88 or T51R, aren't they both bigger than a 3tgte
    Junior Member Grease Monkey johnny blade's Avatar
    Sweden
    This one is not finished yet, but it is a simple manifold to build (I'm not looking for the extra few hp i can get if i build i better manifold).
    I will use a Mitsu TD04 15T from a Saab 95 Aero.
    1 MS55 - 3 TA47 - 1 MS123 - 1 YR21(SR21) - 1 RX80 - 1 ST165 - 1 JZS160
    Last Post: 11-10-2014, 01:02 AM
  2. My high compression + boost concept
    Last Post: 18-06-2012, 10:40 PM
  3. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 01:43 PM
